Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
    Originally posted by Appys View Post
    Where is the file stored after ota update download.. Will try manual update
    for LB 20180803.173707.V0213.userdebug update: https://www.mediafire.com/file/tbwen...pdate.zip/file
    edit (on 8/25): link corrected, should be 48mb file, sorry about that
      Originally posted by dally View Post
      for LB 20180803.173707.V0213.userdebug update: http://www.mediafire.com/file/tbweno...pdate.zip/file
      Where did you find that file?? It is not very big.
        Think it's more of a patch than a new firmware. Don't recall where exactly, will check tonight. I think the error log pointed me in the right direction, maybe root/cache/recovery (after running update app) - that at least is where the install and dmsg log files were.
          On actual LB version of the box, I wasn't able to get the OTA to install either. It would download reboot into the Mecool screen and just hang there. I downloaded the file posted by dally and put it on sd card and shorted pins and it updated fine. Not sure what it was for, maybe it was something to do with the DRM issues the boxes are having. I don't use Netflix and Prime Video still doesn't work
            i installed this update through normal ota process which completed normally on lb version. after update i have a new 'play protect' which is broken even if you disable it. the only way to get a non store apk to install is disable unkown sources, get the error and renable and then you can install. also it seems the wifi is worse.
            does anyone know how to get back to previous firmware which i think was from april and then just install nflix patch and get back to what i had. would like to do this from zip through updater app. wireless is perfect in libreelec. so i am looking for that file or a way uninstall last update. thank for any help.
              Anyone actually happy with this firmware? Any clues on changes?
              i wonder if they fixed the issue where the latest youtube app (on atv version) was crashing?
                Not as a zip (that I could find), but as an .img you'll have to burn to an SD card - http://freaktab.com/forum/tv-player-...804#post725804
                Burnkey tool - http://freaktab.com/forum/tv-player-...327#post738327.
                Altho, after redoing the firmware to 20180417, and having previously run the tool, whatever it did persisted after the reflash and Netflix is fine.
                  BTW, that 20180803.173707.V0213 OTA update is expecting build fingerprint of Amlogic/q20x/q20x:7.1.2/NHG47L/20180417.150752.V0213:userdebug or Amlogic/q20x/q20x:7.1.2/NHG47L/20180803.173707.V0213:userdebug. Anything else will fail.
                    Dear Dev you and your wizardry are sorely missed
                      Anything New to get prime Video to work?
                        Has anyone tried the AtvXperience Amlogic 912 rom? I'm curious you know if it works
                        Inviato dal mio Redmi Note 4 utilizzando Tapatalk
                          Hi guys, the box had worked like a charm for one week, and then WiFi suddenly stopped working! Android can't find any network and CoreElec doesn't even recognize it, I guess... Is the Wifi chip broken? Should I return the box or is there anything I can do firmware-wise?
                          I have the LB version, btw.
                            So ordered one of these and have received it, but no remote was included.
                            Is there any way I can set this up without a remote? I'm trying the Android TV remote app but not having much luck.
                              You can use any dongles remote to get by, but it won't have voice features
                                The $10 Tikigogo one has voice - 2.4G Air mouse with mic on Aliexpress
