Ugoos UT1?
Ugoos UT1?
Ok.
Does wifi work on that kernel? I couldn't get that ROM to boot on my device.
See if you can boot this beta rom with that kernel and see what happens.
RandyRandy
use kernel from 1.2.0 for usb audio.
but you will have constant reboots.
its kind of drm thing so you need to stick with k-r42 firmware.
its not my idea;pEverything is possible if we work together!
Randy
its not my idea;pyeah, I'm using this.
Ugoos UT1?
Ok...it sounds like you have a unique application for this device.
I will stick with the stock kernel in my rom, though...but refer others who need USB audio to try this. Yes it is a solution, but not necessarily ready for prime time...I see some support headaches going that route.
I appreciate your testing of this and keep me posted on your experience. I have plenty to learn about TV boxes.
RandyRandy
Ugoos UT1 Android 4.2 TV Box
Ugoos UT1 Android 4.2 TV Box are amazing. Xbmc working als charm.
here some link for EU http://www.myonlinewinkel.nl/ugoos-u...-hdmi-8gb.html
I disassemble my Ugoos UT1 lastnight (just bought it from China mainland whatever)
The dealer told me that he can give me a good price if i take the Ugoos UT1, not the Kaiboer F4.
He said that Ugoos UT1 is for export only, no retail in China.
But I believe that Ugoos UT1 will be same structure as Kaiboer F4.
Actually, The K-R42(CS-918) in China mainland has 2 kind of stock
Genuine vs OEM, retail price was difference around RMB 80~100 (rmb470 vs rmb380)
Ugoos UT1 spec detail:
Rockchip RK3188 DU31EV 1321 (Quad-core ARM Cortex-A9 MPCore processor)
SK hynix H5TQ4G63MFR-PBC *4 (DDR3-1600,256Mx16 4Gb DDR3)
SK hynix H27UCG8T2BTR BC (8GB FLASH)
Realtek RTL8188EUS 95J92H (IEEE 802.11b/g/n 1T1R WLAN, Max 54Mbps (G) and 150Mbps (N))
ACTIVE 8846QM (Power Management)
ITE IT66121FN (HDMI transmitter)
Terminus FE1.1s USB 2.0 (USB 2.0 High speed 4-port hub controller)
Rockchip RK1000-S H6R410 (Audio CODEC and TV Out chip)
Trxcom TRC1102NL China M 1319 (RJ-45 LAN transformer)
There are currently 2249 users online. 0 members and 2249 guests.
