Download Link
NEW - MK908-Universal Custom rom based on the 8/2/13 tronsmart update
This is the rom that will supposedly work on all versions of the mk908 including v3.0 and can maybe help some people recover from a boot loop. I had a hard time finding a kernel combination that worked well with it. It's got some weird video settings, I think stock it may have the ability to change to 1080p on the fly but the stock kernel still has frameskip. Regardless, here's a repack including a stable kernel that I made, and the stock kernel is included as well just so people have all the options. It's a crappy repack being that I don't have the right kernel sources or settings for this system but it does work. Please feel free to test. Thanks!
Download LinkLast edited by hoabycsr; 11 August 2013, 23:38.If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Tags: None
Re: NEW - MK908-Universal Custom rom based on the 8/2/13 tronsmart update
Originally posted by hoabycsr View PostThis is the rom that will supposedly work on all versions of the mk908 including v3.0 and can maybe help some people recover from a boot loop. I had a hard time finding a kernel combination that worked well with it. It's got some weird video settings, I think stock it may have the ability to change to 1080p on the fly but the stock kernel still has frameskip. Regardless, here's a repack including a stable kernel that I made, and the stock kernel is included as well just so people have all the options. It's a crappy repack being that I don't have the right kernel sources or settings for this system but it does work. Please feel free to test. Thanks!
Download Link
I have some questions...
This ROM resolve problems with netflix and wifi? (Wifi does not run properly,when I use netflix or playstore or some network services, Wifi out of response, but is not a network problem, because all my devices work fine).
The last one... could you provide a tutorial to flash this ROM?
Thanks a lot by your work, and sorry for my poor English.
Enviado desde mi GT-I9300 usando Tapatalk 2
Originally posted by beenii View PostWhile trying to flash, the tool tells me, that "kernel82.img" is not present. i used the kernel.img instead. was that correct, or should i wait for a repack with kernel82 included?If my work benefits you and you want to help out the cause, feel free to
Originally posted by beenii View Posti cant seem to get either RKremote, nor Droidmote to work unfortunatly. other then that, this rom is a huge improvement over stock, as far as i can tellIf my work benefits you and you want to help out the cause, feel free to
I believe I have a new version of the MK908 since only the stock rom from Tronsmart seems to work but with the video jerky its least than usable.
Basically all other roms fail to get passed the boot-screen, today and thanks to hoabycsr I gave this rom a try, at first it seemed like it was going to work but sadly it doesn't for me ;(
Basically, after a successful flash I boot the stick up and I'm greeted with easily the best looking android boot screen I've seen, after that I get the wizard, I yell YESSS! but I spoke to soon, I click skip wizard and then I get black screen.
I think I've narrowed down the problem or least with this room, it seems to be a problem with the USB. Basiclly I can boot the flash but soon as I plug in a USB device to control the device it goes black screen.
I have 2 controllers, one is a gyro mouse with a usb dongle that I assume works on 2ghz and works pretty much on everything I've ever tested it with - it also works with stock rom... additionally I have a Microsoft mouse that also works without any drivers and pluggin this in just makes the screen go black too...
I'm ready to throw this stick at the wall :|
Could this be because my TV is 1080p? - I don't care what resolution it runs at to be honest, just want it play netflix and damn avi files :| - Only had it a week and I'm thinking of flogging it already, what a let down for my first android, that was over hyped on YouTube with no apparent problems :\
Originally posted by polomint View Post...
Basically I follow the procedures of enabling 'Connect to PC' ensuring that disable USB debugging, installing the USB driver in my Windows 7 x64 setup and the flashing tool see's the device in all various flash tools and even reports a succesful flash...
And, after flashing, set power off the 908 ?
Originally posted by VSOP View PostYou do not precise it but have you used "EraseIDB" option before flashing ?
Are you suggesting > EraseIDB > Flash > EraseIDB > Power off?
Is this wrong?
I'm ready to throw this stick at the wall :|If my work benefits you and you want to help out the cause, feel free to
Originally posted by hoabycsr View PostI'm sure sorry to hear that... it's a weird rom and the kernel was different than any I'd seen.. So using one of our current kernels it ends up a little weird. I didn't have those issues but my stick is v1.0 so...
Also can you confirm that my flashing procedure is correct:
Device > Enable USB storage by enabling PC connect
Device > USB Debugging
Computer > Install USB Drivers
Computer > Load Flash Tool
Device > Hold down flash button and insert usb and wait for Bong noise
Computer > Click Clear/EraseIDB
Computer > Click Flash
Device > Unplug after flash
Then plug device into TV and boot as usual.
Originally posted by polomint View PostHow can I find out which stick version I have, I've already opened the case as I didn't have a pin to hit the flash button :P
That sounds about right. The version number is literally printed on the circuit board.If my work benefits you and you want to help out the cause, feel free to
There are currently 2297 users online. 0 members and 2297 guests.
