Many thks to gearbest for sending me the device to play
Thks trebor for the beta test!
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:
- 45% based on stock +/-
- Added Twrp 3.1.1 recovery
- unrooted ( Yes now you can install magisk or whatever you use to root, use the included update app to flash it! )
- Big optimization, is really fast now and i mean fast... you will see it!
- Navigation should be smooth as silk and fast.
- New Boot Logo, many thks to danielelek90 for the great work
- Netflix, youtube, playstore...etc... fully working
- 4k Youtube support.
- initd.d support.
- Enabled Multiuser (Max 3 users)
- Added Status and Navigation's bar's auto hide!
- Enabled round icons, if the apps supports it.
- Fixed Some launchers not working (Nova Launcher...)
- Added lighthome launcher and my custom wetek WebOS launcher, so theirs 2....
- On my Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove/add icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- - Bing Pic of the day background.
- Fixed UI crashes
- Some UI changes:
- - organized the icons on status bar dropdown.
- - fixed and screenshot function on navigation bar
- - removed led control from navigation bar
- - Fixed and added back power button in navigation bar
- PS3/PS4 gamepad support ( only with cable... )
- Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
- Added Dragonrise USB HID game controllers.
- Wifi connection speed should be a little better.
- Permissions fixed. ( lots... )
- Many KL's added.
- Fixed AMCODEC playback.
- Some audio mods.
- FTMC Build 31
- Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
- Optimized some animation stuff!
- Added Android TV screensaver ( default 5 min )
- Added a setupwizard.
- And a lot of other stuff that i dont remember now! ( ye ye i know i need to make notes... )
- In youtube app when you search if it ask to access you microphone deny it or else it will crash.
- Possible a lot more!
Want to buy me a beer?
Download SCV1 IMG:
- DOWNLOAD HERE IMG SCV1
- MD5: EED8278D8C9C971640E227943B913631
Install instructions:
- Use usb burning tool....
Where to buy:
1ยบ BOOT MAY TAKE +/- 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
