[ROM] Magicsee IRON+ - SCV1 - Android 7.1.2 ( "NORMAL" VERSION )
I will like to say thank you for this ROM. I have an Iron+ box with DDR4. Yoir ROM works well after I briked with magicsee's bad ROM (they didn't say that the provided version is for DDR3 boards).
If you have time, can you make some updates to this version of ROM, in regards with thos issues:- Setting up the widgets
- Setting app on Settings > Accessibillity > Services (I've tried for KillApps app and gives me the error: Settings has stopped)
- Allowing navigation button bar to be simple
(I wanted to remove the volume buttons). Not working either from Developer Mode.
Hi Superceleron. I installed this ROM in a VORKE Z1, and I have the problem that wifi and bluetoo do not work. I really like this ROM and some comrade has commented in the forum something that he has achieved, replacing some folders. Can someone tell me what I should do to make the VORKE Z1 work with this ROM with wifi and bluetoo perfectly? I would be grateful. Tremendous work yours Superceleron. Congratulations.
There are currently 2216 users online. 0 members and 2216 guests.
