Updates:
-New kernel built from new sources. 18,000+ on antutu and I think the heat generation is good enough for un-modded sticks. Please let me know because of course I can adjust that.
-New background for the All Apps page.
-Both 720p and 1080p kernels and boot.img files included.
-The blue light works again!
MK908 Android 4.2.2 jjhmod V1.5 Download Link
New Update: 8/15/13 my new batch of kernels made with new (to me) sources that will work on version 1.0 sticks for sure, not sure about v3.0. These are solid as hell on my mk908, and I offer 3 choices in each resolution. Fast, Cool, and Cooler. Fast is 1.7ghz cpu, 800mhz ram, ondemand scheduler default, adjusted voltages for stability. Cool is the same deal with interactive scheduler basically which helps some with the heat and sort-of caps the processor at 1.2ghz. Cooler has the processor turned down as well as gpu speed. Ram is still at 800mhz. This one runs really cool on my stick, even under load. Of course there's some heat but it's the best I've achieved. Anyway, here is the Download Link for mk908-jjhkernel-v3.3.
Many thanks to the community.
Enjoy!
Hoaby
Screenshots:
