Parition the internal eMMC storage
Hmm..
libreelec uses about 200mb of nand space...what remains you can freely use
on mine two devices running libreelec 7 and 8
/dev/system used about 135mb ( size partition 1gb )
/dev/data used 720 mb ( size partition depends on 8 gb or 16 gb unit : 8gb = 5.3 / 16 = 12gb freely useable space )
/dev/xxx is you sdcard
on some devices you can even dualboot : android from nand and libreelec from sdcard
Hope that answers your question
Not really.
I do not want to dual boot.
What I mean to say is that I would like to create 2 partitions on the internal emmc. One called "userdata" lets say. And the other for the LE system.
So when I issue the command "installtointernal" to write LE to the internal, it should only use the system partition, and the userdata partition should be accessible to me to use for storage.
fireboy and watergirl
not sure if here anyone can help , i only know that you need a Terminal App to install
LE to internal EMMC , think i can remember that this what you want is possible , but
better to ask that in LE Forum :
further good luck / gefattern
Originally posted by extremeaudio View PostHi I am using an amlogic 905 device. I am planning to run libreelec on it. libreelec when installed on the internal automatically uses all the space available. I would like to reserve some space for user data. How can I partition? Thanks in advance
In linux you can use fdisk, it's command line but a very good program.
Or there is gparted that has a graphical interface.
Good luck
There are currently 2446 users online. 0 members and 2446 guests.
