MX10 Android 7.1.2 RK3328 4/32GB TV BOX 2.4GHZ WiFi Fast Lan
Hai trebor , picky Am facing a new issue with my MX10 player. My TV Box was working fine after the firmware upgrade until few days before. The purpose of my TV BOX is playing movies from my HDD, it was fine until 2 days where my mx10 is not reading the HDD anymore. Am simply getting clicking sound from the HDD whereas the same HDD is working fine in my WD Media player. Movies from Memory stick is also taking more time to recognize. What possibly may be the issue?? Any Idea?? Plz help me out.
Originally posted by sathiya_sekar View PostHai trebor , picky Am facing a new issue with my MX10 player. My TV Box was working fine after the firmware upgrade until few days before. The purpose of my TV BOX is playing movies from my HDD, it was fine until 2 days where my mx10 is not reading the HDD anymore. Am simply getting clicking sound from the HDD whereas the same HDD is working fine in my WD Media player. Movies from Memory stick is also taking more time to recognize. What possibly may be the issue?? Any Idea?? Plz help me out.
Better not connect your hard drive unless you want it to die.
MAke sure you are using the correct firmware for your device and buy a better power supply.
Originally posted by aka22 View Postinstall magisk manager apk (play market)
install adb drivers (windows) and enable internet adb (android - developer menu)
unzip mag.zip (windows)
go to the folder - mag ,Shift + Right-click and open command window.
1) adb connect xxx.xxx.x.x (xxx= device ip adres) or connect via cable
2) adb root
3) adb remount ( if error,repeat 1) )
4) adb push magisk /system/bin
5) adb shell
6) magisk su
7) mount -o ro,remount /system
finish
do not reboot))))
after each reboot,need to repeat steps 1-2-5-6-7.
It says Latest version 16.0 but installed version 13.2
Do you have a newer magisk file to copy to /system/bin?
File dloaded missing the extension .img just add
I used 2.43 dev tool, worked just leave it all plugged in and let it do it things can take 10 minutes or moreLast edited by trebor; 24 April 2018, 11:46.
First Impression....Slow
Runs very hot
Reboots while rebooting many times for a reason I am not sure as yet
May need to be flash again or with other tool as suggested
I just flashed the Android 8 image on GeekBuying. My MX10 is bricked. Beware!Hey guys, Glad to share the firmware for MX10 Android 8.1 Oreo TV Box PC Flash Firmware Factory Tool Driver Assistant Flash guide, please refer to: http://blog.geekbuying.com/index.php/2016/02/20/android-tv-boxes-flash-tutorials-tool/ Have fun! Note: This firmware is suitable for MX10 Android 8.1 Oreo TV Box.Upgrade to 8.1 systems must use this brush tool. Apr 24, 2018sharon
There are currently 2300 users online. 1 members and 2299 guests.
