You can't change the resolution.
MX10 Android 7.1.2 RK3328 4/32GB TV BOX 2.4GHZ WiFi Fast Lan
I just received the mx10 with android 8.1
Any ideas on the RKMC 18.0 alpha I can't find it to create a shortcut to home screen.
Only way I can open this is to go to settings, then apps then click RKMC then select open
If I try the my apps on home screen the app don't exist
Has anyone else seen this
Originally posted by Dan` View Post
yea i have the same issue, tried simple things like uninstalling and reinstalling with no luck
If you go to System Information it shows Kodi 18 and when playing video it uses normal MediaCodec acceleration, not RKCodec.
They might have messed up and built the app as an AndroidTV app instead of a normal one, that is why you can't see the icon, maybe only in RKTVLauncher, a leanback launcher.
RKMC doesn't have Oreo support, it just works by accident. Rockchip already has full Kodi 18 support for over a year now, but with alpha non tested 8.1 firmware on this, it won't run optimally.
There are problems with .ts and vp9 videos and 10-bit h264 & vc1 playback is also not working.
i just received the mx10 from geekbuying with oreo preinstalled on it. it did not have the upper or lower bar so i figured i should install a different rom on the box so i accidentally installed the MX10 20180515_R2 rom on it using rockchip batch tool 1.8 on it. now the box just gets stuck at boot screen
so i installed the MX10 20180515_R1 and it also gets stuck in boot screen. i tried installing an old 7.1 rom and it still does not work. im not sure what im doing wrong
is it normal for the flash process to only take 1 minute. its a 1.4geg file i expected more time?Last edited by fatso485; 09 June 2018, 19:17.
Originally posted by fatso485 View Posti just received the mx10 from geekbuying with oreo preinstalled on it. it did not have the upper or lower bar so i figured i should install a different rom on the box so i accidentally installed the MX10 20180515_R2 rom on it using rockchip batch tool 1.8 on it. now the box just gets stuck at boot screen
any help would be appreciated guys
is there another 8.1 firmware other than these two.
i tried flashing an old nougat rom....same thing. it takes only 1 minute to flash and it gets stuck on boot screen
Originally posted by UncleJack View PostIt's back from the dead. Nand mask method worked...
Here are the steps for anyone in a similar situation.
1) PC: Open Rockchip Batch Tool, load firmware image (I chose a 7.1 image)
2) MX10: Connect HDMI to monitor. Short eMMC pads (photo 1), at same time press reset switch, then plug USB OTG into PC
3) PC: beeps. MX10 appears as yellow icon in Batch Tool.
4) MX10: release short and reset switch
5) PC: flash image.
6) MX10: When flash finishes, MX10 reboots.
... Erase circle appears on screen (for about 5 secs),
... Mbox logo comes on screen (for about 5 minutes),
... Screen changes to warning not to turn power off (for about 5 minutes)
... UI screen appears.
I had to try step 2 a few times before it worked. You may need an extra pair of helping hands.
Cheers,
Jack.
after doing step two step two. the mx10 box start apearing as blue icon instead of green. after finishing the flash process it gets stuck at the boot screen no matter how long i wait
whats the difference between green icon or blue icon anyway
koyur61, 06-18-2018, 22:25
Great, but is this work really, sounds very good, but did you tryed successfully ?
Работает ето ? Тъй уже попробовал ? Спасибо.Last edited by bangelius1; 21 June 2018, 18:10.
There are currently 1141 users online. 0 members and 1141 guests.
