The new model is called the Mele A1000G, and it features an Allwinner A31 ARM Cortex-A7 quad-core processor, PowerVR SGX544MP2 graphics, 2GB of RAM, and 16GB of storage. the Mele A1000G features a range of connectivity options and input and output ports, 3 x USB 2.0 port, 1 x SD card slot, 1 x Micro USB port.1 x LAN port, 1 x Audio port, 1 x Optical port. 1 x HDMI port, 1 x Charging port, 1 x 2.5" SATA Hard disk port. Comes with hdmi cord, remote control and power supply. youtube video review : https://www.youtube.com/watch?v=VyAKyteBptc
MeLE A31 Quad Core Android 4.1.1 TV Box a1000g Sata dock
Cheapest I found was $114 shipped at deals prime, will post impressions once I get it.
The new model is called the Mele A1000G, and it features an Allwinner A31 ARM Cortex-A7 quad-core processor, PowerVR SGX544MP2 graphics, 2GB of RAM, and 16GB of storage. the Mele A1000G features a range of connectivity options and input and output ports, 3 x USB 2.0 port, 1 x SD card slot, 1 x Micro USB port.1 x LAN port, 1 x Audio port, 1 x Optical port. 1 x HDMI port, 1 x Charging port, 1 x 2.5" SATA Hard disk port. Comes with hdmi cord, remote control and power supply. youtube video review : https://www.youtube.com/watch?v=VyAKyteBptcTags: None
Originally posted by bloatman View PostCheapest I found was $114 shipped at deals prime, will post impressions once I get it.
Stay away from MeLE if possible!
Originally posted by Varming View PostI got one and it's so far the worst Android box I've tried - random resets (factory reset), random freezes etc. The MeLE support is non-existing and the other day they deleted their Facebook page as everybody was complaining about the shitty firmware and support in there.
I've had mine for a few days now and its a bit of mess.As the previous poster said, it hangs and crashes regularly. The CPU is clocked at 1ghz but can be raised SetCpu although raising it makes it completely unstable. I really hope future firmwares can sort it out as its a really nice box with potential.
Sent from my M6 using Tapatalk 4
Originally posted by Batfink32 View PostI've had mine for a few days now and its a bit of mess.As the previous poster said, it hangs and crashes regularly. The CPU is clocked at 1ghz but can be raised SetCpu although raising it makes it completely unstable. I really hope future firmwares can sort it out as its a really nice box with potential.
The main guy at Mele said they have received a new sdk from allwinner and that will hopefully help them to get a better firmware
Originally posted by bloatman View Postposted aug 9 here http://forum.xda-developers.com/show...php?p=44538170
I doubt that we should expect much but time will show.
I'm in contact with MeLE but it's a waste of time, they start over and keep telling me that they will send me a new firmware - but as I'm already on the latest firmware it never happends.
We need help
I tell you if mele find the way with this box is promising I have hope remember that the box has 3 months on the market I don't know way they do this kind of trap to us, put something in the market with a lots of bug and no even a 70% working capability.the mele web site has a forum right look better still in Chinese and a lot of promotion of the M9 system, so I hope one of you gay check into and let is know
Re: MeLE A31 Quad Core Android 4.1.1 TV Box a1000g Sata dock
Originally posted by leafar View PostI tell you if mele find the way with this box is promising I have hope remember that the box has 3 months on the market I don't know way they do this kind of trap to us, put something in the market with a lots of bug and no even a 70% working capability.the mele web site has a forum right look better still in Chinese and a lot of promotion of the M9 system, so I hope one of you gay check into and let is know
Sent from my UMI X2 using Tapatalk 4
Hey guys, I also had the same problem of random reboots with my Measy U4K until I replaced its joky power adapter with a real 2.5A. Another reason is the overheating. A31 has more power consumption than its competitor RK3188 and as consequence more heat generation. So, do something about the heat dissipation and power source and you won't be disappointed. Here is how I solved my problem.
Good luck
Try to install Netflix and check the quality of the picture. Try also to install XBMC and get it to play HD movies with the internal XBMC player - which crashes XBMC after a short time.
I just received the K-R42 today and what a difference! Everything works after installing the custom ROM found at this forum - Netflix picture quality is fine, XBMC just works etc etc. Also just browsing through the installed apps is a joy, a completely different experience than with the MeLE A1000G box.
There are currently 2035 users online. 1 members and 2034 guests.
