MeLE A31 Quad Core Android 4.1.1 TV Box a1000g Sata dock
I get dolby digital 5 channel pass thru but only thru hdmi from my tv then optical to receiver using es music player. mx and built in music player will not play at all. You can also order an adapter that connects to sata dock to usb 3.0. I like how it has 3 usb hosts and takes full size sd cards. A rom based on sdk2 is also coming in early sept according to mele. Next test xbmc
Following the recent release of Android 4.2.2 Jelly Bean, Allwinner keeps improving support for their A31 and A31s platform as they just announced a new SDK 3.2 update to improve the user experience with a fast boot in 5 seconds, shutdown in 2 seconds, the system should also be more energy efficient with 7mA consumption in standby mode. Some other system optimizations are also expected providing a smoother user interface and better scores in benchmarks software: ~4600 score for 3D Mark or 60fps with Epic Citadel. Allwinner ODM and OEM partners have access to the SDK update and should soon provide firmware updates to their customers.
Originally posted by bloatman View PostFollowing the recent release of Android 4.2.2 Jelly Bean, Allwinner keeps improving support for their A31 and A31s platform as they just announced a new SDK 3.2 update to improve the user experience with a fast boot in 5 seconds, shutdown in 2 seconds, the system should also be more energy efficient with 7mA consumption in standby mode. Some other system optimizations are also expected providing a smoother user interface and better scores in benchmarks software: ~4600 score for 3D Mark or 60fps with Epic Citadel. Allwinner ODM and OEM partners have access to the SDK update and should soon provide firmware updates to their customers.
Originally posted by Batfink32 View PostI've had mine for a few days now and its a bit of mess.As the previous poster said, it hangs and crashes regularly. The CPU is clocked at 1ghz but can be raised SetCpu although raising it makes it completely unstable. I really hope future firmwares can sort it out as its a really nice box with potential.
Sent from my M6 using Tapatalk 4
Originally posted by Varming View PostWhere did you get the info about an update coming this weekend??
Heat problem
Originally posted by ADD View PostHey guys, I also had the same problem of random reboots with my Measy U4K until I replaced its joky power adapter with a real 2.5A. Another reason is the overheating. A31 has more power consumption than its competitor RK3188 and as consequence more heat generation. So, do something about the heat dissipation and power source and you won't be disappointed. Here is how I solved my problem.
Good luck
Originally posted by leafar View PostHow do solve the heat dissipation problem can you be more specific
droidmote working?
Has anyone got droidmote working with this box? Installing busybox breaks Rom storage memory. Had to do a complete wipe and go back to 1.2.5 with sdcard flashing method. It hasn't crashed since then but still it's not as fluid as it could be. The hardware is not bad, the software needs big improvements.
There are currently 1845 users online. 1 members and 1844 guests.
