Sent from my PMID701C using Tapatalk
****OFFICIAL Polaroid PMID701c THREAD! root, market, and more!
You should be able to disable the 3G radio by just going into /system/app and either deleting phone.apk or renaming it to something like phone.old
not quite that easy
Originally posted by Finless View PostYou should be able to disable the 3G radio by just going into /system/app and either deleting phone.apk or renaming it to something like phone.old
Does this thing even have a 3g radio physically in it?
This is the same thing the Arnonva does but if there is no physical radio it should not be effecting battery life period.
In your "settings" do you have a phone settings for the 3g radio?
If not, go to the market and get an APP called anycut.
Install it
run it
choose short cut
choose activity
This will now list all possible things and many of them are hidden settings the manufacturer took out (hide). There are usually all kinds of phone related choices in there. Click one and it will put a icon on your desktop.
A prime example is if you guys dont have "accounts and sync settings" in your settings menu. You can get to it this way. There maybe more than one choice for the same thing in the list. Some will work and others may not. Keep choosing them until you find the one that works.
See if you can find the phone radio toggle. If the airplane APP worked that means the settings are in there just hidden from you.
Bingo
Notpod's dumps were very helpful!
Unlike many other ROM this one uses init.rc and init.sun4i.rc
Init.sun41.rc is where the partions are being mounted. All the mounts in init.rc are commented out.
Below is the init.sun41.rc. I have bolded the mount commands and you can see /system is ro. Easily changed once we know how to flash etc.
By the way this ROM is kind of a MESS! It has busted sym links and stuff all over it!
_______________________________
on fs
mount ext4 /dev/block/nandc /system wait noatime nodev barrier=0
# try to mount /data
wait /dev/block/nandd
mount ext4 /dev/block/nandd /data wait noatime nosuid nodev barrier=0
setupfs /dev/block/nandd
umount /data
exec /system/bin/logwrapper /system/bin/e2fsck -y /dev/block/nandd
exec /system/bin/busybox mount -t ext4 -o noatime,nosuid,nodev,noauto_da_alloc,barrier=0 /dev/block/nandd /data
# try to mount /cache
mount ext4 /dev/block/nandg /cache wait noatime nosuid nodev barrier=0
setupfs /dev/block/nandg
format_userdata PMID701C
on boot
chown root root /system/xbin/su
chmod 6755 /system/xbin/su
chown system system /drv
chmod 0777 /drv
#insmod key & tp driver
#insmod /drv/sun4i-ts.ko
insmod /drv/ft5x_ts.ko
insmod /drv/sun4i-keyboard.ko
# insmod mali driver
insmod /drv/ump.ko
insmod /drv/mali.ko
# insmod gsensor driver
insmod /drv/mma7660.ko
# nano wifi module and firmware
chmod 0777 /drv/x_mac.axf
#csi module
insmod /drv/videobuf-core.ko
insmod /drv/videobuf-dma-contig.ko
insmod /drv/ov7670.ko
insmod /drv/sun4i_csi0.ko ccm="ov7670" i2c_addr=0x42
#usb net module
insmod /drv/usbnet.ko
insmod /drv/asix.ko
insmod /drv/rtl8150.ko
insmod /drv/qf9700.ko
insmod /drv/mcs7830.ko
mount ext4 /dev/block/nandc /system ro remount
mount rootfs rootfs / ro remount
#start memsicd service
#service memsicd /system/bin/memsicd
# oneshot
#init ethernet for adb debug
#service ipconfig /system/bin/sh /sbin/ipconfig.sh
# oneshot"Pzebacz im, bo nie wiedzą, co czynią"
That happened to ME, TOO!
Originally posted by sabercatpuck View PostDid that with root explorer, set permissions to r/w and changed it to phone.old. system went into a neverending round of force closes. I was finally able to hit the shutdown commands between the force close messages and after restart was stable with phone.old still there. I am still showing the bars with an x up top.
Yeah, I know what you mean. Scared the you-know-what out of me. I hit the RESET button on the back of the tablet, and let the tablet reboot.
I thought I'd BRICKED the puppy! Now that I know I can take phone.apk out without issues, I'll delete it again.
73 DE N4RPS
Rob
I Noticed That File, Too
Update: So far, it appears to. Root and /system are now r/w without running Root Explorer.
However, I'm awaiting feedback about this from those who know more about the details of what goes on behind the scenes than I do...
73 DE N4RPS
RobLast edited by N4RPS; 01 April 2012, 23:33.
Originally posted by N4RPS View PostCould full true root access really be as easy as modifying that statement? With RootExplorer, that file could easily be changed. Of course, assuming that the ROM reads THIS file on startup.
73 DE N4RPS
Rob
So boot.img needs to be permanently modified to keep that statement RW.
Figured what the heck
Since it seemed to be a big question and I figured I wouldnt likely totally brick it out with my CWM backups I gave changing the permissions in init.sun4i.rc with Root Explorer a shot. Didn't boot up to any permissions the first try (might have gotten a bit impatient) so I rebooted again and straight into Root Explorer it say's it is R/W now.
Hmm might try the CWM install again to see if I can get it to go from power off now
Originally posted by Finless View PostThis statement is in boot.img so next reboot your changes will be gone and it will be back to what it was. Well at least if this ROM works like many others? Pretty sure it does
That is correct. It seems to stay if you reset with the RESET button, but if you power off, it reverts back to the value in boot.img.
73 DE N4RPS
Rob
Well that's interesting but....... But you really should never just reset android os.. Like Linux it should be shut down . There are databases and files open and you can corrupt them by doing a reset.
Anyway it seems unlikely rk29 a reset just reloads the system and does not do a full reload using boot.img like a full power down.
Originally posted by Finless View PostWell that's interesting but....... But you really should never just reset android os.. Like Linux it should be shut down . There are databases and files open and you can corrupt them by doing a reset.
73 DE N4RPS
Rob
There are currently 1747 users online. 1 members and 1746 guests.
