Vorke Z6 Review
@toymandek .. Preferably a 12V 1 amp fan(size 50x50 mm- 2.6mm high) below the main motherboard. Any U shape plastic/pvc channel 90 /95 mm wide for the bottom base. From here get cracking. Will the adapter power cope with the extra 1 amp ? I have ordered a special adapter 12V 4 amp ( which costs me US 4.00) from China.to compensate. Pls send me a picture of your bottom ventilation unit when you finish the architectural design.Thanks in advance.rgds
Just purchased 3g/64g Z6 from Geekbuying. Android V7.1.2, Kodi 17.6, Immediately after power up it started rebooting at random times. Sometimes It would run 8 hours before reboot but other times 5 minutes.
Tried turning off wifi, Bluetooth, apps, etc. to no effect. The only thing that made a difference was when I changed resolution from 4K to 720. At 720 it would reboot every couple days instead of every few minutes.
Any ideas before I throw it under a bus?
hello.I plan to buy this product.as I am confused.I heard for some categories like:android tv box that can't run all apps,doesn't have statusbar etc....and android box like any android device.can someone tell me what kind is this?will I be able to run every single app like I do with my phone?also is my choice good?or do I have to look for something similar?thanks.
Originally posted by JoseM
i have the same box
Στάλθηκε από το VORKE Z6 μου χρησιμοποιώντας Tapatalk
There are currently 4514 users online. 0 members and 4514 guests.
