Vorke Z6 Review
Originally posted by kwabh//_ KOS25K ---The contents inside the box is exactly a Z 6 with relative specifications exact as all Z 6 boxes. So no need to WORRY . It will be OK when installing and make some initial trials.Check which firmware you have in the device. whether it is the latest ( Jan 2018 release). Enjoy .
Originally posted by kos25k View Postthanks dude.is my first tv box and at first I thought it was a plastic clone!so small,light and cheap plastic.also power adapter is super light compared from other devices.but when I connected it..wow wtf!! Now I want to put a 5cm fan connected to 1 of 2 usb ports upside the box by making a big 5cm hole to steady tight.I hope usb voltage cuts off when I turn off the box,so fan also stops.Also my firmware is VORKE-Z6-20171221.Is latest right?thanks
Originally posted by JoseM
VORKE-Z6-20180126 is the latest use update&backup app to install ota update
Στάλθηκε από το VORKE Z6 μου χρησιμοποιώντας Tapatalk
//Kos25k. ... A good advice. As this is your first box, so firmware update would be NEW operation to you(in case you have never done it previously). In case the box is running smoothly, do not try to update the firmware at this early period, until you understand the procedure. This is what I have done.I would also pray you to get the approval of SENIOR members.
About the fan ,it is advisable to diminish the risk of overheating in the long run. .Now that you plan to use a fan connected one of the USB ports, automatically it will draw its power from the motherboard. If you are using a 5VOLT 2 amps or 2.5 amps for the Z6 , it is advisable to use a 5 Volt 3 Amperes(maximum) Wall power adapter for the device. The board will suffer in the long run if a PSU more than 3 amperes.is used. I would solicit the approval of the more experienced MEMBERS to express their advices on this point. Thanks for their coming forward and guide new users rgds
really thank you dude,your help is precious!So I suppose I have to use a power adapter or my tv's usb also?I installed cpu temp xposed module and as I have the temp always on my statusbar,i unfortunattely notice high temps (maybe all boxes work like this) compared f.e with my Xiaomi mobile,look the differences:On xiaomi I have 24° on idle,30-34° on usage and 40° on heavy usage.On Vorke I have:62° on idle,67-79° on usage and haven't tested on heavy usage yet!!! Ok Xiaomi devices generally work veeery cool compared to others.But an average temp of 75° is not acceptable (at least for me) for long time period hardware life and properly work of the device.So if anyone could help on how to connect-place the fan,I would be grateful!
Because you did not prepare to elementary knowledge of the box. you taxed it as garbage. Remember what garbage is to one user, for others it is a normal box with much advanced features .Would advise you
to explain clearly to others (on the forum) what you did since receiving the box. Some angel might then possibly help you. But please explain clearly what you did and what firmware you used.
Originally posted by neomodeHello,
Do you have the Vorke Z6 right?
Neomode
There are currently 2586 users online. 0 members and 2586 guests.
