Scishion V88 can't install firmware
    I have scishion v88 4k it came with android 6 and many problems, i tryied to flash the android 5 firmware but bricked, i have done it before, change firmware without problems.
    The other times the Rockchip batch tool 1.8 and Android Tool 2.35 recognized the boxes as: found one Loader Device this time because there is no recognision, i open it and put a clip at pins and the programms now says : found one MASKROM Device but in this case can't install firmware, i tryied everything, i don't know what else i do, help me guys.
    You can'
    You can't switch between Android OS versions without doing an 'EraseFlash' otherwise you will brick your device.
      And....can i do anything to save tv box or should i throw it in the trash?
        Hello,
        if you have V88 with blacks ports (AV & SPDIF), only working roms with loader version 2.32.
        2.31 never working and create an error when flashing.
        There is no solution, you must install a rom with 2.32 loader version (all are android 6)
          Hello,
          I have exactly the same problem. I have flashed Android 5 to a V88 box with blacks ports (AV & SPDIF) - board is MX4VB.
          Now I can get to MASKROM with shorting pins 5+6 but in AndridTool I get only:
          Dowload Boot Start
          Download Boot Fail
          Is there any solution? I think that loader is now corupted... Can I somehow upload 2.32 loader?
          Thanks.
            Originally posted by mitjas View Post
            Hello,
            Dowload Boot Start
            Download Boot Fail
            Thanks.
            Hi ,
            please try to "eraseFlash" with AT and then flash the Rom .
            good luck / gefattern
              Hi
              Even "EraseFlash" returns the same error:
Name:	AndroidTool v2.35.png
                Same here. It seems that the firmware for this revision is not available (yet?)
                  I have same issue is there any news about that?
                    I have the same problema and I can“t find any solution.
                      I have tried upgrade_tool in linux ( http://www.hotmcu.com/wiki/Flashing_..._Rockchip_Tool ).. device is detected in MASKROM, but then the same error "Download boot Fail".
                      Well if so many users have this problem, then this is not hardware problem as I thought...
                      Hopefully we will find right firmware, that will work on MX4VB board.
                        I also have this tv box with the same problem of dim red light. I have already tried all the ways to try to save it and I get exactly the same mistakes as yours. What I can say is that I buyed it in gearbest where they give you a link with the most current firmware. Previously I had flashed with that firmware without problems on several occasions (at least 10 times) because I happened to have problems with application closures, reboots or loop boots. Until today I wanted to turn it on and the dim red light has come out. So maybe the nand memory does have any kind of damage?.
                        By the way, my board is MX4N
                          I have same problem as you. Any idea, how to load android back to the device? MX4VB.
                            hi guys , i have the same issue , is there any rom for MX4VB motherboard of v88 4k yet ?
                              Perhaps it's working with the last firmware (11/10/2017)
