Scishion V88 can't install firmware
    so i think you have hw damaged your device
      well if it gets HW damage from unplugging it .... yeah its trash anyway and no big deal, i got a firestick now and the adapter for Hardwire Ethernet coming in a day or two, so as for the v88 , Its junk anyway, i was only trying to fix it to let my brother use it till his box gets ordered, then i was going to use it on my back tv that never gets used LOL.
        So i will search on internet about your problem first what i know this problem will cause when you have connected SD Card in device next try to make lower format before you make upgrade in androidtool after that you will try to flash new rom
          and last question you will trying this in maskrom mode?or loader mode because if you trying via loader mode this will happens because trying update bootloader check this http://wiki.radxa.com/Rock/flash_the_image its probably helps
            im in maskrom mode when i try this.
              hmmm i am using windows 8.1, ive read to disable somthing in win 8 when doing this but if i disable this its not able to pick up anything. Anyone know a work around? maybe a Virtual Machine of win 7 ? i have access to 3 PCs in my house but all are running win 8.1.
                my box starts in maskrom, not loader, so i dont know anymore. its really becoming not worth my time.
                  i can't help it, i'm trying this on my V88 Plus, MX4M *cross fingers*
                    Hi, somebody can help me to get access to the batch tool, The first time I can get into and start the reboot but then the error ocurrs and fail the boot loader and only have the red led, so I was reading additional info and see something about flash the nan with a short in pin 4 and 5 but I´m not really sure..
                    My tvbox is a v88
                      Thanks for the image. Finally have unbricked my V88 box with image for MX4VR. Board is MX4VB
                      Found today this image for Board MX4VB. Maybe this image will also unbrick the device. Did not tried out yet.
                      rk3229_7.1_MX4VB_SSV6051p_zhongx_20171209_v011_Spe ctek.zip
                      Download https://yadi.sk/d/weKOyhxQ3R9z4F
                      I have this firmware but when it gets to Idb it fails any suggestions
                        I get the Idb fail any suggestions
                          Try some software for Nexbox a95x r1 with 3229 chip it has similar hardware as V88.
                            oI não consigo o download da firmware tx_mx4vr_v01 alguém pode mim ajudar ?
                              Originally posted by mitjas View Post
                              Hi
                              Even "EraseFlash" returns the same error:
Name:	AndroidTool v2.35.png
                              olá, estou com o mesmo problema,exatamente igual. será que os colegas já resolveram esse problema,ou jogaram no lixo? agradeço pela ajuda dos colegas.
                                Can anyone send me a picture how to short the points ? i cant get AndroidTool to recongnize my device , i know several time has passed since any1 replyed here , but i will give it a go , i know there is a link here for that but is dead and i really dont know what pins to short. Reset Button dont recognize any device by the normal way
