Alfawise S95 Amlogic S905W Android 7.1 2/16GB ROM 2.4GHz WiFi 4K 100Mbps LAN
    Originally posted by acaN View Post
    Hi! I can confirm that p281-ota-20171228.zip of Tanix TX3 Mini flashes (via stock UPDATE APP), boots and works OK on Alfawise s95. The only thing i didn't check is Wi-Fi, but it should be OK too.
    Perfect...
    Did you use the previous version (p281-ota-20171228) of the LibreELEC + Android firmware? Whose current version is: p281-ota-20180109.
    Did I understand correctly?
    Thank you very much!
      Thank you for that info. I will try it .
      Please post a download address
        See in the acaN post footer
        It's next to the MEGA logo. In the word MEGA.
        Ok?
          Originally posted by webipsum View Post
          Perfect...
          Yes. I used p281-ota-20171228. I see reports that 20180109 has issues with freezes, so I chose not to flash it.
            Any advantages or disadvantages to flash with Tanix TX3 p281-ota-20171228 rom??
              Thank you.
              I'll use the: p281-ota-20171228.
              Do you have the original firmware of the Alfawise S95?
              Big hug and grateful for attention.
                Thank you.
                Could you post your results after updating the Alfawise S95? Did Wifi worked ok?
                I also would like to have the stock Alfawsie s95 in case things get awry.
                  OK.
                    baruchin.
                    I installed the firmware Tanix TX3 (LibreELEC + Android firmware) (p281-ota-20180109.zip).
                    Before applying the firmware in question I backed up the Alfawise S95 using the TWRP as directed in this post: http://freaktab.com/forum/tv-player-...329#post703329.
                    It's too early to give a final opinion ...
                    LibreELEC + Kodi, running 100%.
                    Android running 100%.
                    Wifi running normal. Although, I tested quickly because I prefer to use network cable.
                    Hugs.
                    Note: See next post...
                      acaN.
                      How is your S95 running with Tanix Tx3 Mini firmware version: p281-ota-20171228.zip (LibreELEC + Android firmware)?
                      I installed the version: p281-ota-20180109.zip (LibreELEC + Android firmware), but it is freezing.
                      Today watching a 48-minute video, the device froze 2 times. I had to remove the power cord to restart.
                      Grateful for the attention.
                      Note: And you warned me, you remember?
                        acaN.
                        Are freezes happening also on Kodi LibreElec? That's the main OS I'm intending to use the box with. It's nice to have Android for quick emergencies though.
                          So far, I've only watched a video on LibreELEC + Kodi of 42 minutes without any problems. So, I used LibreELEC + Kodi only once.
                          Freeze occurred on Android using BS Player. I'll continue testing ...
                          CPU temperature equal to 69 degrees Celsius. Is this normal?
                          Note: The sugestion of acaN is version: p281-ota-20171228.zip
                            Hi guys. My box is stuck on boot. Is there any reset button?
                              Hi Paulo
                              They forgot to punch the hole in the box. I opened the box and inside the bottom lid has the mark of where the hole should be. I made the hole.
                              But if it is just to enter Reboot Recovery mode, to upgrade (with zip file) and not with IMG, you can use the Quick Reboot [ROOT].application.
                              Hugs.
                              EDITION:
                              In fact you do not need the hole for the recovery reset:
                              If:
                              1)FLASH BY PC
                              This tutorial teaches you how to do it:
                              or
                              B) UPDATE FROM TF/USB MEMORY
                              App Update pre-installed.
                              or
                              Quick Reboot [ROOT]
                              Bye.
                              Last edited by webipsum; 30 January 2018, 18:27. Reason: In fact you do not need the hole for the recovery reset...
                                Hello is there a chance to run Stock android tv Nexus rom ? On this device ? I also see that device is very similar to mecool m8s pro w
