Alfawise S95 Amlogic S905W Android 7.1 2/16GB ROM 2.4GHz WiFi 4K 100Mbps LAN
hola minha tv box alfawise s95 não da imagem e o visor da frente não liga tambêm porem a entrada que fica do lado da entrada av acende uma luz e só onde fica o botão de reset dela alguém sabe dizer por gentileza whats +5571993541480 inglês hello my tv box alfawise s95 not the picture and the front display does not turn on too but the entrance that is on the side of the entrance av lights a light and only where is the reset button of it someone knows to say for kindness facebook.com\viniciusaevedo
Originally posted by viniciusazevedo View Posthola minha tv box alfawise s95 não da imagem e o visor da frente não liga tambêm porem a entrada que fica do lado da entrada av acende uma luz e só onde fica o botão de reset dela alguém sabe dizer por gentileza whats +5571993541480 inglês hello my tv box alfawise s95 not the picture and the front display does not turn on too but the entrance that is on the side of the entrance av lights a light and only where is the reset button of it someone knows to say for kindness facebook.com\viniciusaevedo
Originally posted by webipsum View Postbaruchin.
I installed the firmware Tanix TX3 (LibreELEC + Android firmware) (p281-ota-20180109.zip).
Before applying the firmware in question I backed up the Alfawise S95 using the TWRP as directed in this post: http://freaktab.com/forum/tv-player-...329#post703329.
It's too early to give a final opinion ...
LibreELEC + Kodi, running 100%.
Android running 100%.
Wifi running normal. Although, I tested quickly because I prefer to use network cable.
Hugs.
Note: See next post...
Originally posted by pajopasa View PostAnyone have success in changing the Launcher in this box??
In either case, if the launcher is ORANTH, after installing the NOVA Launcher or another Launcher:
1) I installed the application:
System app remover (root needed)
https://play.google.com/store/apps/d...ystemapp&hl=en
2) And with it I backed up and then deleted the files:
Oranth_Launcher_720P.apk
Oranth_Launcher_720P.conf
Note: I am currently using an older version of the Apex Launcher.
:-) Sorry my English. I speak Portuguese...Last edited by webipsum; 03 October 2018, 00:58.
Originally posted by webipsum View PostAre you using the original S95 firmware or the Tanix Mini firmware?
Im Portuguese also.
Im using the original firmware and inst rooted, and a tried to root it but without sucess.
Did you get it rooted, to do that?
Or are you using the tanix firmware?
Cumps
Currently (for several months now) I'm using Tanux TX3 fiurmware:
>-> TX3Mini-ota-20171220-Tanix_Box_Com.zip
>-> http://www.tanix-box.com/download-vi...mage-20170829/
I tested other current Firmware from Tanix TX3, but the one that got working better was what I'm using.
There are currently 1710 users online. 2 members and 1708 guests.
