[TWRP] LibreELEC for S905x plus EXTRAS!! (NEW)
Rootz Have you tried Acestream with CoreELEC Leia ?
I tried today using your method after copying .tar to config .
I had to install Plexus as it isn't in this package: http://freaktab.com/forum/tv-player-...425#post706425
Code:cd /storage/.config tar -xzf acestream_3.1.24.2_ARMv7.tar.gz rm -f acestream_3.1.24.2_ARMv7.tar.gz
Code:#!/bin/sh ( /storage/.config/acestream/autostart.sh )&
edited acestream-user.conf and marked with a hashtag # because it wouldn't start.
#export RUNAS=daemon:nogroup
That got it started but no stream opens. Failed to load lists after start and get the failed notification after 1 minute of Downloading notification.
kostaman I'm using Acestream 3.1.29 with coreelec Leia that works fine, not sure about this version.
If I upload it later and tell you to need to edit the autostart.sh to suite will you be confortable with that ?
I don't have much time to offer support or give step by step guides.
Sent from my SM-G950F using Tapatalk
Originally posted by Invisable View Postkostaman I'm using Acestream 3.1.29 with coreelec Leia that works fine, not sure about this version.
OK download this..
pop it in the storage/.config folder
Untar it like you did the other engine
Once untared, your notice you have another folder called acestream.engine the start script is inside this folder so your have to modify your autostart.sh to suite.
Code:( /storage/.config/acestream.engine/acestream.start )&
If you look in....
/storage/.config/acestream.engine/androidfs/system/etc
Your see there is a hosts file you can use "there's only a couple of extra lines"
Ok once done reboot your box.
When it's loaded you should be able to remove the old ".acestream" folder from the .config directory.
You should also be able to edit settings of the engine by simply using another device on your network with a web browser and typing.
Code:http://IP.adresss.your.box:6878/webui/app/ReplaceMe/server
kostaman.
Yes I believe all the settings are in this version.
I know caching to disk is preferred if you want to watch a Torrent file
I just cache to Ram as i only use for Acestream links but you or anyone do use it for Torrent files I believe you need enough free space to download the whole Torrent or else you get kicked out.
I've not played around too much with it. I just set max peers to 100and off i go.
With this WebUI version you can also add playlists, we can let our little Amlogic boxes do the backend stuff and enjoy the playback on any device with a web browser, I've not personally tested it though.
One other thing I've noticed. A few times I've had to edit the host.conf file again, I'm not sure if it happens with some Elec updates it reverts to default so just a heads up if it
Originally posted by Invisable View PostCan you log in via putty and run a few commands to double check.
Have you commented out the line in the acestream-user.config?
Code:nano /storage/.config/acestream/acestream-user.conf
Exit and save ( ctrl & x and answer y )
Probably also best to run these commands
Code:chmod 777 /storage/.config/autostart.sh chmod 777 /storage/.config/acestream/autostart.sh
If it still doesn't work see what happens if you try and start the engine without using the autostart script.
Code:cd /storage/.config/acestream ./autostart.sh
I tried editing the file you mentioned and I removed the "export RUNAS=daemon:nogroup" line and it does actually appear to have solved the problem - sort of.
I've tried a couple of acestream channels and one has worked so far, but then the majority go through downloading, starting acestream engine, playing torrent and then .. nothing. they just tick over and eventually time out.
it *might* be my broadband connection or ISP though, but i'm going to try a few more later this afternoon when there's more soccer on TV as there seems to be a wider selection of acestream options then.
sorry again for forgetting all about this ..
Hello, I installed these bolt-ons from Pinguy's old thread but now I don't use emulators and want to free up space on my device and remove all related addons and data.
Can someone help me do so?
I found the post below, I think this way I can remove this acestream engine but I don't really recall what else I have to remove and how I can do it.
I mean...just remove these addons like emulationstation and retroarch?
Originally posted by Invisable View PostSorry I haven't had anytime, I'll write something properly later I'm on my phone so probably be spelling mistakes as phone likes to autocorrect etc...
Obviously you need a ssh and ftp client personally I use a couple of apps on my Android phone (juicessh) and (ftpcafe) to save me firing up the laptop.
Step 1.
Download the tar file Rootz posted and stick it in /storage/.config use winscp or something I'm not sure if you can curl from zippyshare ?
Step 2.
If upgrading from Pinguys version your need to remove old acestream engine, chances are it's already running so you won't be able to remove it, for ease its probably best to first change the autostart.sh file first and reboot so It's not running.
Code:nano /storage/.config/autostart.sh
Ok now we can reboot by simply typing
Code:reboot
Once rebooted, we can now remove the old engine and scripts, extract the new engine and tidy up.
Code:cd /storage/.config rm -r acestream rm shutdown.sh tar xfz acestream_3.1.24.2_ARMv7.tar.gz chmod +x autostart.sh rm acestream_3.1.24.2_ARMv7.tar.gz
Once rebooted you should be good to go, however it's worth noting all the Acestream setting are in file called acestream-user.conf if you want to change the number of peers, cache etc it's done here, but you won't see the changes until after a reboot (see post 37)
To edit it from ssh
You may need to comment out this line (put a # in this line of the acestream-user.conf)
ctrl & x and answer y to save.
Sorry it's brief see how you get on maybe we get to tidy it up later.
I installed acestream succesfully with this post above from Invisable few months ago on several devices with libreelec.
But now, i cannot install it neither way. It just keep saying ''acestream is not installed''. is it possible that this is some kind of problem ith new plexus 0.1.8., some kind of incompability or something like that ?
Edit : Works perfectly with 0.1.8. I did not copy # in one line on acestream.conf fileLast edited by Axe; 17 September 2018, 17:21.
Hey,
anybody knows how to play magnet links from within Kodi and Plexus and Acestream? I know this is possible using the webinterface, but I would like to be able to play from Kodi directly.
Example:
Code:works: 'plugin://program.plexus/?mode=1&url=http://link.to/file.torrent' not working: 'plugin://program.plexus/?mode=1&url=magnet:?xt=urn:....'
Ok soooo - i have X96 box.
Libreelec instaled on sdcard - not internal.
Now i buy second device (Same model).
Teory:
If I pull the card from the first device, if I put it in the second one - I will run it from the memory card (it's exactly the same model) will it all work? My library, settings, etc.?
I dont want setting up second device from scratch - if that metod will work i just clone sd card
Originally posted by zambu View Postim loking for
acestream_3.1.24.2_ARMv7.tar.gz any one?
or the lasted version
NOTE IMPORTANT !!!!
If your have using an autostart.sh your have to modify it as the start/stop scripts are in the "acestrem" folder rather than the "acestream folder"
Code:https://www88.zippyshare.com/v/hMQXPDad/file.html
If upgrading stop the old acestream engine and delete the " acestream.engine" folder from the .config dir
download the new tar and pop it in the storage/.config folder
Untar it
Once untared, your notice you have another folder called acestream.engine or ( acestrem.engine) the start script is inside this folder so your have to modify your autostart.sh to suite.
To get the web user interface to work your also need to edit the "hosts.conf" file in the .config folder too.
If you look in....
Here you go, version 3.1.33
NOTE IMPORTANT !!!!
Untar it
If you look in....
There are currently 2623 users online. 0 members and 2623 guests.
