[TWRP] LibreELEC for S905x plus EXTRAS!! (NEW)
Originally posted by Invisable View Post
Originally posted by Axe View PostThis zippyshare link from posts above doesnt work anymore. Does someone have a link for this or maybe even newer version of Acestream ?
Originally posted by gricenkmak View PostCan this ROM run on MagicseeN 5 ?
You will have your Android OS untouched internally.
Your box will boot first time every time into CoreELEC with the SD Card inserted.
You can choose boot to EeMC / Nand from power menu
Your Box will reboot to Android.
Hello everyone. On the subject or CoreELEC, does anyone have an insight on how one should install the latest coreELEC on an A95X in light of TWRP already installed?
Should one revert to factory settings and recovery beforehand or does some clever person have an .IMG to make things happen?
Thanks in advance..
Originally posted by Axe View PostAcestream don't work anymore on Libreelec ?
"failed to load file" message every time when trying to start stream.
I looked into a easy fix it at the weekend and found a working solution...
I suppose the (most user friendly) easiest way to fix for everyone is to use the built in kodi file manager. (If you rather use ssh to remove just make sure you execute the acestream.stop command first)
click show hidden files in "interface" settings
navigate to /storage/.config and delete the old autostart.sh file ( or remove the acestream start line if your using it for something else)
Reboot
Navigate to /storage/.config and delete the acestrem or acestream folder.
Then install this repo:
And install the Acestream service addon
This one should auto update
Originally posted by Invisable View PostAcestream changed the way their platform works a few months back, i believe they stick advertisements in the old acestream still works but you need to create an account and save it in one of the conf files.
Reboot
To be more precise, you need to install the repository through this addon: https://github.com/lysyiklad/repokod...ysyi-1.0.1.zip
Install it from: addon > install from zip file
Then you have to install the acestream service addon, go to: addon > install from repository > lysyi > services > Acestream Libreelec
Link to TWRP recovery in original post is broken as memoryleaks.org is gone. I can't find TWRP for S905X anywhere
There are currently 1647 users online. 3 members and 1644 guests.
