[ROM] T95Z Plus 3GB/32GB - Android 7.1.2
    Hi Everyone,
    I've received this update from a seller of the T95Z 3GB/32GB variant.
    Android Version: 7.1.2
    Build: T5ZP1015
    Security Patch: August 1 2017
    Kernel: 3.14.29
    WIFI/BT chip: AP6255
    Major Fixes:
    Google Play upgrade/downgrade loop. (Fake Play Store gone)
    Wireless AC functions properly
    I had originally posted this in another thread but removed the download link since it was doing an upgrade loop. I've contacted the vendor and they said it was a test update to ensure the OTA was working and they forgot to remove the test file.
    Last edited by Karce; 08 November 2017, 14:08. Reason: update links, added wifi chip info
    Originally posted by Karce View Post
    Hi Everyone,
    Build: T5ZP1015....
    1) This firmware is for WIFI/BT chip AP6255, not for LTM8830/QCA9377.
    2) Link above is working only with copy-paste, direct click leads to another place.
      Hi all, so 1015 is for 3gb & 2gb? What does your ram show? Thanks
        For 3GB, chipset name is q201_3G
          Thanks for catching that. I corrected the link. I copied it from my mailbox, and it sends it through a redirecit/scan script prior to opening the link.
          Should be good now
            Has anyone tried this ROM with Antutu I get a message that 3D is not supported. Anyone else? TZ95 Plus AP6255
              My box was never described as having 3d support, so I doubt it
                Do you think they have firmware for the T95K pro model?
                  The seller sent me the firmware T95KPRO-7.1-912-3GB-v1073 for the T95K PRO 3GB / 32GB.
                    Hi, I installed this room on my T95Z Plus 3/32 and it is OK except that it shows me that the network adapter is 100 and not 1GB. How does it show you?
                      Unfortunately I can't confirm, I originally bought the box to give it to my dad, and he uses Wireless N. I only tested AC when I had the box and that was working with this update.
                        Salve a tutti, sono nuovo del forum, ho installato questo firmware sul mio box T95Z PLUS 3/32 , funziona abbastanza bene, ma se installo qualsiasi app per lo speed test non va,Succede anche a voi?
                        Grazie
                          can this be flashed on 2GB/16GB version?
                            NO, è solo per la versione 3gb - 32gb - WIFI/BT AP6255
                              Originally posted by svalley View Post
                              can this be flashed on 2GB/16GB version?Â*
                              No, 3/32 version only
