[ROM] T95Z Plus 3GB/32GB - Android 7.1.2
    Amico Karce, io ho un Box T95Z PLUS 3/32 GB con AP 6255, ed ho aggiornato alla 7.1.2.che hai indicato nel forum. Funziona tutto abbastanza bene tranne le app per lo speed test ( tipo Oocla).Succede anche a te? puoi consigliarmi un app per lo speed test che funziona con questo firmware?
      You can try bandwidthplace (http://www.bandwidthplace.com/), google speed test (http://speedtest.googlefiber.net/) , Bell Canada (http://support.bell.ca/Internet/Internet-Speed-Test)
        grazie per i link che hai postato.... ma intendevo un'app di Google Play... https://play.google.com/store/search...t&c=apps&hl=it
          Hi. I've buy Sunvell t95z plus 3/32gb. I have problems with freezes and wifi droping.
          full details on box on link http://specdevice.com/showspec.php?i...3-c5870033c587
          I need right firmware for this box.
          Thanks for sugestions.
            Hi, i just install the rom but i see now that the display menu in settings where you can zoom in zoom out + the hdmi option have gone any idea how to get that back ? Also is there an option to change the default keyboard mapping for changing the langueage from search+ spacebar to shift + spacebar ?
              whitch rom version did you install? and what model is yours box ? wifi chip?
                Hi again , i got the 3g+32gb model with AP6255 wifi , install the firmware posted on the first post by Karce Build: T5ZP1015, but in the settings the display +hdmi option have been disapeard
                  You can find in applications "droid settings" with display and hdmi options
                    I couldn't answer that question, however, you can remap individual keys by modifying generic.kl in /system/usr/keylayout
                      Original remote controler is working ok? This firmware have no problem with wifi dropping and system frezzes? Did you update fw with sd card?
                      I got mine sunvell 3/32 with ap6255 and bugy firmware T5ZP1073 (system frezzes and wifi is dropping connection) ... i'm looking for stabile fw and with no function lose.
                        Hello,
                        I used the USB Burn Tool in order to flash the firmware. WIFI stable (including AC). Original remote working (also use Rii 8+ mini) with no issues.
                          Hi. Finaly i detected problem. Problem was not FW, but nougat and settings on my router. Funny with android 6 there was no problem... I tried fdifrent FWs.. now smooth runing T5ZP1075 (i see no diference comparing with T5ZP1015..looks identical FW).
                          Another thing... USB Burn Tool.. my correct procedure was ... holding reset...USB plugin... (windows detected box) and then i started USB Burn Tool.
                            Hello guys, i need some dire help.
                            i have a 3G 32GB variant with AP6255.
                            my wifi was broken hence i browsed thru and was flashing the firmwares using tooth pick method.
                            1st attempt. - my recovery didnt boot at all. no HDMI signal was going to the TV
                            2nd attempt - managed to boot to recovery and flashed the firmware. wifi was not fixed.
                            3rd attempt onwards i could never get into recovery.
                            looks like my sd card marker is missing some boot files.
                            appreciate someone could guide me the extact steps and files i need for recovery to work.
