MVR9 RK3328 Nougat ROM by mo123
    Originally posted by philip83 View Post
    Hello,
    did you find out about supersu?
    I saw it said su binary occupied if trying to use SuperSU.
    So I have to try 3 different things to test and change to see if it solves it.
    Maybe I will find a solution today.
      How do you fix the Amazon video Playback? Please help us
      • mo123
        mo123 commented
        Editing a comment
        You have to rebuild the whole firmware, it isn't something you can just quickly change yourself.
        You can ask the manufacturer of your device to provide a firmware update, otherwise if you are using this device it already works as it gets ota updates.
      #18
      Firmware updated, rooted version & unrooted version.
      64-bit SPMC now
      Fixed .TS video playback
      HDR support in Kodi 18 / SPMC
      Reduced volume steps for quicker change
      Track graphic buffer mode in OMXNodeInstance
      IMediaExtractor: ensure users to check returned value by getTrack.
      Soundtrigger service: fix cross deadlock with audio policy service
      Fix issues with extractor dumpsys
      OMXNodeInstance: use a lock around OMX::freeNode
      m4v_h263: fix global buffer overflow
      Fix memory leaks
      Settings: Fix crash when disconnect wifi
      AudioPolicyService: Acquire mutex for SoundTriggerSession
      media: Fix a typo in parsing nclc atom.
      Fix information disclosure in mediadrmserver
      Settings: back icon doesn't work in format SD as portable page.
      Settings: Fix settings force close
      audiopolicy: fix unexpected output selection for direct pcm usecase
      audioflinger: fix for playback paused during track transition
      audio: Update anchor time for offload playback post resume
      sepolicy: Also allow vendor_file text relocations
      sepolicy: Allow system apps to access selinuxfs
      video/rockchip: rga2: reduce work timeout to 100ms
      video/rockchip: rga: fixup render_mode parameter incorrect
      video: rockchip: fb: add fb ser par support 4k output
      Still waiting for a SuperSU fix, will be ready end of next week.
        Some shortcut keys, hidden menus screenshots to make life easier:
        Press the menu key to get extra settings to add Samba or NFS shares in the Media Center app.
        Click image for larger version  Name:	1.jpg Views:	1 Size:	145.9 KB ID:	696046
        While a video is playing press the menu button to access extra settings like below.
        There is a new HDR menu.
        Click image for larger version  Name:	2.jpg Views:	1 Size:	154.6 KB ID:	696047
        Long press the power button to get the power menu.
        Click image for larger version  Name:	3.jpg Views:	1 Size:	147.6 KB ID:	696048
        Extra System Tuner menu under More Settings - Modify the statusbar icons etc.
        Click image for larger version  Name:	5.jpg Views:	1 Size:	77.2 KB ID:	696049
        SPMC/ Kodi 18 working great with HDR, 1080i, real 4K videos and frame-rate switching.
        Optimal Settings set by default.
        (Kodi 18 has a bug with the mouse pointer not working in 4K resolutions on all Android tv boxes that use 1080p
        UI resolution, so it's recommended to use SPMC that doesn't contain this bug)
        Click image for larger version  Name:	4.jpg Views:	1 Size:	114.5 KB ID:	696050
          Something interesting in the works.
            Hi ,
            a nice Info for all / Netflix & Co / Fans , good luck
            greetings / gefattern
              hi mo123,
              in yours version 1.1 is no hdcp support. is this for a future version?
              phil.
                hi mo123,
                phil.
                Some new patches were found to help with SuperSU on Nougat.
                But it will take a while to test it and make sure it works.
                Google increased security a lot from MM to Nougat to prevent things like root.
                Yes, future ota update will contain L1 DRM, HDCP.
                I will try to test it today or tomorrow and provide some feedback what it can do.
                I will upload the original firmware too.
                • trebor
                  trebor commented
                  Editing a comment
                  Look forward to the L1
                  Great
                #24
                Click image for larger version  Name:	drm.PNG Views:	1 Size:	185.3 KB ID:	697908
                How did you get L1? I recently wiped my L1 keys from M8S PRO L would be nice to get them back
                • mo123
                  mo123 commented
                  Editing a comment
                  This is for Rockchip RK3328, it won't work or help for Amlogic devices that implement DRM differently.
                  If you wipe your DRM keys, they are gone forever, you can then only send a device back to the manufacturer so it gets reflashed or replaced.
                  I think on Rockchip the DRM keys are permanent and can't we wiped like on Amlogic but not 100% sure, will have to find out more. So if you flash it on a Rockchip device on a different device it was made for you can't change the kernel or do modifications then DRM cease to work, when you then try to flash DRM firmware your manufacturer later makes the DRM won't work since it was already flashed a previous time and linked to a different firmware.
                #25
                So how have you added L1 keys? I'm generally interested and a bit confused.. are you saying this box already has the L1 keys flashed from factory its just missing library's etc in firmware? or this just included in new OEM firmware you got?
                I have seen leaked documentation from amlogic on how widevine, hdcp, playready etc.. keys are flashed, its just acquiring them.
                • mo123
                  mo123 commented
                  Editing a comment
                  It's a new tv box with DRM L1 already added, not by me.
                  But there will also a new ota update to add it to older devices, not sure how it will work, it's still being experimented with to see if it can work.
                • trebor
                  trebor commented
                  Editing a comment
                  Will it be Netflix certified is the big Q
                  Hope so one of the only good 3328 PCB about or should I say firmware
                #26
                programs as adaway and trimmer (fstrim) starts not automatically. is there a possibility to make it automatically?
                • mo123
                  mo123 commented
                  Editing a comment
                  In the launcher, you can try to press menu button(top right)on the ir remote on an app icon to see info, uninstall or launch on startup.
                  But I think those apps need root, not sure if they also want SuperSU(which will be improved soon).
                  My ROM's already block adds by default and you will almost see no ads in Chrome or Lightning browser.
                  There are also other browsers like NoChromo or Tugabrowser with built-in ad-blocking too.
                #27
                ok. thank you mo123 for you great work.
                phil.
                  phil.
                  I got SuperSU v2.82 app working correctly now.
                  I will upload the new ROM now after testing it one more time.
                    New ROM v1.2(Rooted ROM)
                    -SuperSU v2.82 working - Enable Root from Developers Settings first and update su binary after installing SuperSU app.
                    -Updated APKPure - Faster download of apps
                    -Removed SPMC, Kodi 18 works fully now and should be used instead
                    -Updated video codecs
                    https://mega.nz/#!1IFCWKZQ!34lnfk855...fH8hWjJK4xhEuk
                      Not sure why as yet still looking into,
                      Bit of a quirk in YT...
                      Plays in Background 100% as soon as you go onscreen with YT Stops or stalls, esc out to background mode plays weird
                      Both Installed and Store version
