Full support for HD audio, 4K, HDR, deinterlacing and 10-bit h264 in Kodi 18 at least on my firmware.
MVR9 RK3328 Nougat ROM by mo123
an news regarding Oreo?
For Rock64 it is also released, but Android Tool doesnt like it, maybe i try the MX10 image :-D
http://wiki.pine64.org/index.php/ROC...droid_8.x_eMMCLast edited by x7soc; 25 June 2018, 10:40.
The MX10 is a disaster so don't waste time installing broken firmware that might damage the bootloader and stop the device from booting.
The R64 Oreo can only work from a micro-sd card, emmc firmware uses strange methods to flash and can only work on actual R64 hardware after you pull some switches, the emmc storage chip on it is a removable one you buy separately that work and boot differently since it doesn't come with built-in storage by default like tv boxes.
Originally posted by bylderup View PostCan I flash your image via original update app or do I have to use the flash tool an my laptop ?
Hold a paperclip in the recovery opening until it clicks while doing the following, connect the USB cable to the side USB port next to the blue one and recovery opening and connect the power cord to a wall connector or use an extension cord if too far away. You can now release the paperclip.
Also install the Driver Tool first if it is the first time connecting the device to the PC or laptop.
If the steps were done correct, AndroidTool will say Loader mode found'.
You can go the the second tab to select the firmware file, update.img then Update to flash it.
Wait about 5 minutes after flashing completes then remove the cables from the PC and plug into your tv.
Android Kodi I build included in my firmware supports Mpeg2 deinterlacing, HDR, 10-bit H264 and auto frame-rate switching(which is a bit broken in the nightly Kodi 18's since they have no Android developer to test things properly).
I will probably upload a new custom firmware in a few hours too.
Will release new firmware this weekend.
There was a big bug with Youtube playback not working correctly I needed to get fixed.
This firmware will be the only RK3328 one with fully working Youtube without freezes and playback problems.
I see lots of changes for LibreELEC support was made this week, so hopefully a new image will be released this weekend.
hardly can wait :-). It COULD be the first time (over years !) that maybe AMLOGIC can get a competitor in case of "Live TV (deinterlacing 50hz and so on...).
Let´s wait an (hope) to see it soon :-).
regards
arel
New ROM released.
- Based on new code
- Removed mouse mode with long pressing the back button since it might activate accidentaly
- Fixed Youtube videos would get stuck and not play, a problem on all RK3328 devices, my ROM is the only working solution now.
- Add newer deinterlace support for Kodi
- Updated apps
https://mega.nz/#!RIsS2aoB!lb-Nm6Rw7...xNkX5BPLd-y62k
Pass: mvr9
I have just installed your new ROM. But device is dead now although it said everything is fine. Android tool made a reset when finished, so you see "no device found" in the screenshot.
When I plug in the power cord the blue LED is on and TV screen remains black. Tried it a second time. Programm said everything ok. When the device is resetted then TV starts up and for a short moment there are some circles and text "Erasing" . that it..
Problem is I couldn´t save the original firmware before.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by bylderup View PostI have just installed your new ROM. But device is dead now although it said everything is fine. Android tool made a reset when finished, so you see "no device found" in the screenshot.
I will just double check this afternoon when back from work then reupload the firmware if so.
You can then just reflash and everything should work fine, it's not possible to break the device in any way.
I will also try to make a guide how to easily backup the whole firmware and restore it with all the settings and apps already installed.
Here is the link to the previous firmware.
Pass is mvr9 or nagrace
So everyone can just wait a bit so I can test or reupload it.
OK. I had a download of your 1.5 FW Version made some days ago.
Installed it. V 1.5 is running.
Maybe it was my fault. With Version 1.6 I waited about 10 minutes, then plugged USB cable and power off, reconnected to TV and powered on.
This time I only removed USB cable after 10 minutes and plugged HDMI cable and LAN cable in, but didn´t power off.
But I will wait now until you took a look on the new FW.
There are currently 4064 users online. 0 members and 4064 guests.
