Will release an updated ROM around Thursday to fix everything.
MVR9 RK3328 Nougat ROM by mo123
New ROM released v1.8b
https://mega.nz/#!oI93wK4D!E2W73wPfj0HkZscFsaNbPEGa9VXkSAzOSdLpFYnRFVk
Pass: mvr9
- Fix Youtube, Netflix
- Kodi 64-bit can now also play 23.976, 29.97, 59.98fps
No need to deselect 0.47hz anymore
Follow all previous steps to set up the whitelist in Kodi
Bqeel MVR9 RK3328 Nougat Custom ROM v1.7b by mo123 - 05 Aug 2018 Changes v1.7b - 05-08-2018 - Fix Spotify issue - ROM version added - Fixed Bluetooth connection -
- Improved bluetooth headphone, speaker sound output quality
- Add support for Magisk systemless root
When opening the app, say Full install and after that install the other package it asks for then restart your device.
You can hide apps that check root or Safetynet in MagiskHide
Do Eraseflash then Upgrade when flashing the firmware otherwise Google Play might have problems logging in.
I fixed the screensaver issue so the screensaver can turn on correctly now.
Please post working screensaver/daydream apps I must include in the next ROM.
There will also be lots of Kodi improvements once I make an Android Pie firmware in 1-2 months.
I'm experimenting to see if I can make an Oreo firmware before that.
Latest LibreELEC also runs well now and supports HD Netflix, Amazon Prime Video addons.
Originally posted by mo123 View PostI fixed the screensaver issue so the screensaver can turn on correctly now.
Can you build your new rom for 4/64gb models. I have x88max+ and h96max + both are with 4/64gb. I need your costom roms actually everybody needs. No one develops new roms for 3328s except you. Thank you for your effort.
I don't have those devices.
If I make a ROM, the manufacturer should at least provide an Android SDK and a contact for support if I get stuck to help with problems.
Then I also need a sample device to test if the firmware can boot and work.
I don't have 20 hours to troubleshoot for free why firmwares don't boot on random devices with no support anymore.
Google also increased security a lot in newer OS's like Oreo, Pie, so it is now almost impossible to make custom firmwares for devices without source code, as firmwares will refuse to boot in most cases if you just change one file. The days of easy custom firmwares like in the past on KitKat, Lollipop, Marshmallow are gone now.
New MVR9 Oreo Custom ROM v1.0 released.
Bqeel MVR9 RK3328 Oreo Custom ROM v1.2 by mo123 - 09 April 2019 Changelog v1.2 - Added power off icon - Added Screenshot function - Added Hide Bar function - Added Sleep function - Added Home menu to change launcher - Added USB menu - Added Hide navigation bar menu - Fix Kodi auto frame-rate switching, all frame-rates are
I have now installed the rom version 1.8b, it does perform pretty good compared to my old tv box, however i noticed the root function is not working or corrupted.
Sometimes when enabled it does take forever for the "grant root access" popup to appear other times nothing happens, it does not save granted requests. The SU binary is occupied.
Some apps like CPU Z and Buid.Prop (Jrummy) are not compatible with the device (lol), when using youtube vanced i cannot watch 4k content on my 4k tv it will start loading 2160p on click but no video only sound can be heard.
ill try to downgrade to 1.7b again (will use factory tool to format flash)
I do like the new app drawer and the statusbar, would be awesome if you could disable either the statusbar or navigation bar or both, as these elements cause lag on 4k tv with framerate interpolation when browsing youtube. Somehow the Ethernet feels slow, like i start background playback on youtube then come back after some time and it has to reload the video for 3-4 seconds before it does continue.
I used androidtool to upgrade firmware and it wont let me erase flash i will try the 1.7b maybe that fixes root?
I have rooted using the full settings app in developer settings, box reboots, now there is superSU app and magisk app, if i go on supersu "binary occupied" if i go on magisk it does update the MagiskManager and then fails with the message "magisk not supported" please install newer magisk manually, app does close if i click ok
i will try 1.7 now again
Hy, i was so happy to found a better rom for the mvr9 box as this was installed by the manufacturer.
So i flasht it successfull without any problems. Thank you very much for this work with the rom. :-)
But i have one question about the launcher. i cannot change the apps in the boxes or place any widget, or also i want a different backgrount picture... i sech now about two day,s a customize able launcher and nothing work, or is very bad. This "hphtvlauncherex" is sure like i want, but i not understand how to do? I try,d serching in the net about, but nothing to find... :-(
Can anbody explane me how to do?
Sorry, my english is not so good, (but i hope everybody understand).
So, i looking forward and be happy if somebody answer me.
There are currently 4139 users online. 0 members and 4139 guests.
