Greets
NEW NEXBOX A95X S905X Android 7.1 Firmware 1G/8G, 2G/8G 2G/16G
Originally posted by SemNizzle View Post
For android 7.1 you not use remote.conf any more, I got chinees qbox or what ever is called, to get my remote work I need to edit dtb files. But got stupid bug can't wakeup device
If someone interested here is my build repacked with mxq pro 4k remote config and twrp 3.2.1 just extract img and replace dtb files in you build.
Link: https://mega.nz/#!p0t3VS5T!0Ou-eif26...Hpwsdy33grqOBc
md5: 55FAF6471210874DDD2D981C44272426Last edited by jas7o; 10 March 2018, 11:39.
Originally posted by SemNizzle View PostFor those who want to run 1080p on the NEXBOX 1G/8G, take the firmware of 2G/8G and install through Burning Tool it also runs and you have 1080p Resolution
GreetsTronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by jas7o View PostFor android 7.1 you not use remote.conf any more, I got chinees qbox or what ever is called, to get my remote work I need to edit dtb files. But got stupid bug can't wakeup device
Under linux, customization tools break img
Use this tool aml_image_v2_packer
https://github.com/khadas/utils?files=1
Originally posted by jas7o View PostDownload file and replace orginal in /system/etc you remote should work. Easiest method.
ok quick update... your remote config works great!
Hi guys
someone could help me with the original remote.conf file of the A95X Pro box. I put the firmware of the Mecool M8S PRO W to revive the HD netflix again. everything is excellent but on the remote control the shutdown button does not work and so I read when replacing it with the remote.conf stock of the A95X Pro should work again.
Now you have to pull the power cable to turn it off and connect it to turn it on.
Thank you
There are currently 4069 users online. 1 members and 4068 guests.
