NEW NEXBOX A95X S905X Android 7.1 Firmware 1G/8G, 2G/8G 2G/16G
    Can I port it to MXQ PRO 4K?
    Thanks.
      I have the 2gb 16gb, android 6.0, I have tried to update it and I can't get it, can you give me a hand or pass me a manual.
      thanks
        i flashed x96 from nexbox a95 android 7.1. but the x96 remote does not work on this firmware.Is there anything I can do to make the remote work?via root, the explorer moved the remote.conf file to the system / etc root folder.
        but it didn't give any result.somebody help me please
          Buena aplicación
            I NEED A95X R2 S905W FIRMWARE
              Hi ,
              maybe this :
              if this is your Box , check this before , remember must be right Wifichip
              good luck / gefattern
                descargar
                  descargar nuevo firmware nbox
                  • gefattern
                    gefattern commented
                    Editing a comment
                    English , please translate your posts
