I dunno if it's the rk3299 itself to be slow, if it's the low ram (1gb) or simply the rom (the only working 5.1 rom for this board seems to be faster, but it doesn't have wifi and lan working).
MXQ-4k Bricked < Test Device Failed > (RK3229) (H27UCG8T2ETR NAND) (R329Q_V2.0)
Originally posted by santana View Post
Maybe a 5.1 should be better.
What's the difference.with the other 6 Android link?
According to me, the 7.1.2 release is faster than the first Android 6 you posted.
I found how to upload dumps.
Copy the forder Image in the folder of RK_Android_Tool_2.3.5. Then rename config_16.cfg to config.cfg and overwrite the config.cfg from the Tool 2.3.5.
Open the program, check the parameter and load the parameter file from dumps, format device, then click download.
santana : try this https://mega.nz/#!hORQTALS!tJEm9UT_M...qHAHkbycq5sCoE
It's a Marshmallow ROMs for MX4VR board with AndroidTV
Originally posted by DS-1 View Postsantana : try this https://mega.nz/#!hORQTALS!tJEm9UT_M...qHAHkbycq5sCoE
rk3229_7.1_MX4VB_SSV6051p_zhongx_20171209 is good
There are currently 1805 users online. 0 members and 1805 guests.
