If a TVStock rom hasn't been made yet, can someone give me some direction in how to make one?
[FIRMWARE UPDATE] MXQ PRO+ ANDROID 7.1.2 AMLOGIC S905X 2GB/16GB TV BOX
The process stops at 4%, any ideas?
here is the final part of the log:
[21:52:42 732][HUB6-2][Err]--generatedAddSum:0xfc1a4d74;srcAddSum:0xc5e130e0;ru nResult:0x e6;paraMagic:0x7856efab
[21:52:42 732][HUB6-2][Inf]--ReadCheckPara failed
[21:52:42 732][HUB6-2][Inf]--m_iFileIndex:0
[21:52:42 810][HUB6-2][Err]--[0x11000902]Unknown
[21:52:42 810][HUB6-2][Inf]--Close device handle 0x0000042c
I want to share my discover with you:
**ID: USB_BURNNING_TOOL 2.0.8 or newest [SOLVED]**
Description: parse burning image fail
Solution: Unpack .img like zip!!!
**ID: ReadCheckPara failed with [0x11000902]Unknown [SOLVED]**
Description: Installation process stuck on 4% with message in log: ReadCheckPara failed; [0x11000902]Unknown; I didn't change temp in app.
Solution: Check motherboard by android system info. Compare model board with img file(some people add it to img name). This error mean that you img is not for your board(board is more important then device model). Manufacter build the same model with different motherboard. Problem isn't related with cabel or usb_burnning_tool verison.
My motheboard p212_9377; device MXQ PRO+ 4K; CPU S905x. I used img for tx7 from https://mega.nz/#!8VxwyDLK!swvvVOEe-...DBpJH64ky1f-Po. KODI, Netflix, eth, remote controller work
Person help resolved problem: pawel1234q from forum.android.com.pl (THX A LOT)
Hi, When I try to burn the image on the device it keep failing at 2%. I got Amlogic S905
[17:41:11 042][Global][Inf]--Scan usb device
[17:41:11 042][Global][Inf]--Aml scan WorldCup Device
[17:41:11 051][Global][Inf]--Host: USB xHCI Compliant Host Controller
[17:41:11 051][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9c31&subsys_08661025& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[17:41:11 051][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&f7fa012&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[17:41:11 052][Global][Inf]-------->[Port0]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port1]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port2]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port3]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port4]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port5]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port6]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port7]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port8]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port9]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port10]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port11]NoDeviceConnected
[17:41:11 052][Global][Inf]-------->[Port12]NoDeviceConnected
[17:41:11 053][Global][Inf]--Host: Intel(R) 8 Series USB Enhanced Host Controller #1 - 9C26
[17:41:11 053][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_9c26&subsys_08661025& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[17:41:11 053][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&ee05782&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[17:41:11 153][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&1ee1784f&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[17:41:11 153][Global][Inf]---------->[Port0]NoDeviceConnected
[17:41:11 153][Global][Inf]---------->[Port1]NoDeviceConnected
Hello Guys I need some help please, I have an Android TV Box- G9CX (MXQ Pro S905X) (link to product Http://www.shiningworth.com/en/Produ...uct/id/58.html we had a power cut and now when I plug in the power all I get is a red light from inside, the blue light on the top does not come on and nothing on the screen, I have tried to flash it using USB burning tool, From version V20.0.4.3 to v2.0.9?. but all I keep getting is ?parse burning image fail? I have tried at least 6 different image file from different sites including China gadget, so any help would be brilliant thank you, i am using a windows 10 PC. tried renaming the images to .zip but then the usb image burning tool does not see the file!!!
regards
Bazza
Guest : since you mentioned shiningworth I would like to ask wether you know the CQ II box S905X based 1/8. I tried several custom roms but remote does either work partially without ability to power on/off OR does not work at all. Could you advise how to solve this?
#44.1Guest commented28 January 2019, 22:45Editing a commentWe never really got a multi-ROM for S905X (p212) from Shiningworth, unfortunately. It was in development, though, and maybe superceleron can point us to an OEM release.
That said, there are Android 8.0 beta releases for p212 and the Amlogic 9.0 SDK supports it. My understanding is that the 9.0 SDK is 99% final.
Sorry mate i cant really tell you of a more OEM, since the development on 7.1 stopped!
About 8.0... forget it is dead!
So best bet now is 8.1, and yes 9 is 99% there
Thanks, Luis!
soldiaz, if you want to experiment with OREO 8.0, here's the link: https://forum.freaktab.com/forum/tv-...ing-needed-wip
Otherwise, we just need to be patient. At least the S905X is supported in the Amlogic SDK 9.0, unlike the S912. I'm surprised it wasn't supported in the Amlogic SDK 8.1, though.
Actually I bought really cheap s905x instead of s905w due to Android 8/9support.
I am not a coder/Developer. I am facing issues with stock remote which does not work with several custom Roms. E.g. my box boots up nexbox a95x, atvx and several other but remote's on/?ff Button does not work....since atvx is based ?ff tanix I thought bout replacement Remote...and Change remotes
There are currently 1351 users online. 0 members and 1351 guests.
