Simple question. Given your experience, which box would you recommend, the Mecool M8S PRO L or the Sunvell T95Z Plus? They're both S912 running Android 7.1 so basically it boils down to the 'brand'.
Which? Mecool M8S PRO L or Sunvell T95Z Plus
Originally posted by clarkss12 View PostThe Mecool M8S Pro L supports Widevine level 1 and HDCP-1.x which means this box can play Netflix in 1080P with DD+, and I don't think the Sunvell T95Z Plus can do that.
From trebor topic on the mecool m8s pro L here, the box:- doesn't seem to have a reset button
- it has the ATV version of android
The first issue can be solved by manually shorting the pins whilst the second issue will limit me to install apps which are only in the Android TV store (not sure if there is a work around for this).
Originally posted by Katandbri View Post
Unfortunately, I cannot find details of the Sunvell T95Z Plus (3GB/32GB) version.
There are currently 1265 users online. 0 members and 1265 guests.
