SU app alternatives
    Originally posted by Lakuma
    Reaper Man Hmm, I bought mine from GearBest about the same time as you did for your buddy. I wonder what in the world am I'm doing wrong? I flashed successfully two different times with SCV4 and it won't boot into Android during this install. I then flashed up to SCV7 thinking it might fix it but still no go. I opened up the case to verify all the hardware:
ID:	693064Click image for larger version
ID:	693065Click image for larger version
ID:	693068Click image for larger version
ID:	693067Click image for larger version
    Hmmm. Mine is blue and a lot different than Yours - 1 RAM chip, 1 ROM, etc...
    It probably doesn't matter when we talk about soft, but still it's different.
    Sent from my Z2 Pro using Tapatalk
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      Lakuma
      I believe that my board does have the same mfg date, 14 of Oct. All the same, Hynix ram, Aigale (print on the chip is wague, almost not visible at mine).
      So you are saying that scv4 (and on top OTA v7a) is not working? Burning tool or sd? Havent tried since there was no confirmation that sc works on newest pcbs with 8 ddr3 modules.
        churla Yes, you are correct, I installed SCV4 via USB Burn Tool and tried to boot but it wasn't displaying anything. So I installed SCV7 on top of SCV4 via SD card in TWRP but got the same results, just a black screen.
          @ Lakuma,
          I was mucking with my cables trying to fix a Youtube issue and plugged my China Box into the HDMI V2.0(60Hz) port. No picture(black screen on Vizio 4K), switched back to 1.4(30Hz) port and all was fine(not Youtube).
