VORKE Z6 PLUS ANDROID 7.1.2 S912 3GB/32GB TV BOX FIRMWARE UPDATE
    As Found 08/03/2018
    Glad to share the firmware for VORKE Z6 Plus TV Box
    PC Flash Firmware
    www.mediafire.com/file/u7a17oar5ex42sh/VORKE-Z6PLUS-20180126-PC.zip
    SD Flash Firmware
    www.mediafire.com/file/uwgn55nu07p2nd5/VORKE-Z6PLUS-20180126-SD.zip
    Source: Blog.geekbuying
    PC Flash Firmware(Rooted)
    http://www.mediafire.com/file/u4jnx7...-rooted-PC.zip
    VORKE-Z6PLUS-20171027-rooted-PC
    SD Flash Firmware(Rooted)
    http://www.mediafire.com/file/fidb3n...-rooted-SD.zip
    VORKE-Z6PLUS-20171027-rooted-SD.zip
    SD Flash Firmware(Noroot)
    http://www.mediafire.com/file/1ugjc3...-noroot-SD.zip
    VORKE-Z6PLUS-20171027-noroot-SD.zip
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Source blog.geekbuying
    VORKE Z6 PLUS ANDROID 7.1.2 S912 3GB/32GB TV BOX FIRMWARE UPDATE 20171221
    2017/12/25
    As Found not tested:
    http://www.mediafire.com/file/g5mlyl...0171221-PC.zip
    http://www.mediafire.com/file/ai2mmq...0171221-SD.zip
    Change log:
    1. Improve WIFI throughput, optimize network speed.
    2. Repair automatically restart and crash.
    3. Repair blurred image when booting.
    4. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
    5. Add ROOT switch to Set (set to be restarted to take effect).
    6. Add video playback frame rate adaptive switch to Set, off by default.
    7. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
    8. Add ariscreen apk, support airplay IOS 11 version, chromecast and so on.
    9. Remove the speed test app and update the KODI software version to 17.6.
    With this firmware 20171027 tv box restarts and the picture freezes. If someone wants to use the tv box until the new firmware, install a SCV4 BLUE (LPDDR3) PCB IMG. I briefly tested and no problems with freezing and rebooting. No WIFI works only via LAN. LCD not working, others not tested.
    http://freaktab.com/forum/tv-player-...7-wifi-chipset
      I have problem with the new update, every time the tv box boot up the screen resolution is 480p if I'm changing it in the settings for auto resolution it's not helping, its still booting in 480p
        Bluetooth does not work as well, it´s a pity because I would prefer superceleron rom to the stock firmware, it´s incredible how bad this firmware can be
        How did you get the idea to try superceleron rom?
          Hos do install this firmware? I have z6 plus and running firmware from 20171221 and its not Good box is hanging so i have to cut power and restart.
            I have to admit that I'm addicted to flash
              Lol, good that you share your results!
                just google it, for instance "flash amlogic s912" and watch some videos about it
                also look posts in this forum, there is much information about it, the procedure for Vorke Z6 Plus is similar to all the other amlogic s912 boxes
                good luck
                  Ok. So this SCV4 BLUE (LPDDR3) PCB IMG firmware Will work on my z6 plus?
                    Apparently yes, but then wifi and bluetooth are not working and for me this is a big issue, it would be great if superceleron could adapt his blue rom to the Vorke Z6 Plus/Tanix TX9 Pro
                      This issue is associated with incompatible bootloader. Do not use OTA, try burn img via USB and if it now works then the flash is not for your hw.
                        Very true, I also had the same problem and I solved with flash from pc.
                          Does anyone have a problem with WIFI connection?
                          my vorke z6+ cannot connect to internet. however, no problem with wired connection.
                          while using wifi connection, miracast is working good.
                            No, I tested both the stock roms and the Nexus version modified by Alianato and I never encountered any Wifi problem. I still modified the TV Box by putting an external antenna to further improve the reception of the wifi signal (if the signal is <70 Db does not connect).
                            Please note that the update via OTA of the original firmware 21122017 causes various malfunctions, so it is always better to use the flash with the tool "USB_Burning_Tool" (2.0.9 in my case),
                              My wifi problem has been solved. I've change my wireless router Channel Bandwidth from 20 to 20/40.
