VORKE Z6 PLUS ANDROID 7.1.2 S912 3GB/32GB TV BOX FIRMWARE UPDATE
Has anyone experienced a lot of apps crashing with this box? I thought it may have just been an issue with the 10272017 firmware but have flashed the newest 21122017 firmware and experience apps crashing constantly. Kodi, Playstore etc. Running Kodi 17.6 it randomly crashes, sometimes I can get a video to play but then it will crash back to the home screen. Also tried SPMC and that crashes right after it starts up. Just wondering if anyone else has come across this issue.
Originally posted by ozzman666 View PostHas anyone experienced a lot of apps crashing with this box? I thought it may have just been an issue with the 10272017 firmware but have flashed the newest 21122017 firmware and experience apps crashing constantly. Kodi, Playstore etc. Running Kodi 17.6 it randomly crashes, sometimes I can get a video to play but then it will crash back to the home screen. Also tried SPMC and that crashes right after it starts up. Just wondering if anyone else has come across this issue.
I flashato the first version of @Alianato's ROM "https://uptobox.com/upda24jofc3j" with Burn Flashing tool 2.0.9. This ROM is fantastic.
Read this thread and you will find my comments and the whole story.
Bye
Originally posted by Luca View Post
Hi, I also had the same problems, practically useless. The problem in my opinion is due to the temperatures that quickly reaches the box inside and to suffer I think it is the DDR more than the CPU. Now I put the 4x4 fan put copper on cpu and ddr and the box works perfectly without any restart or other block.
Bye
Welcome
Lots of reading to do.....
There are a few ways to update firmware
Via OTA the box does an update from supplier Over The Air/Ethernet when and if available. keyword Search OTA Update
Via SD card, use special software to create and update to install into unit with SD card keyword Search SD Card Maker
Via USB burning tool, direct connect to box Via USB OTG cable, USB Burning tool, and Updated software. keyword USB Burning tool
Lots of reading
Understand what the deal is before doing the task and check dates are fairly current.
Check out my article if you have any trouble upgrading the firmware on the Z6 Plus box!! Especially if you brick it.
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/mecool/719769-vorke-z6-plus-sd-card-firmware-update-20180126-sdLast edited by Sol-geek-newbie; 12 November 2018, 23:07.
Originally posted by Sol-geek-newbie View Post
I even succeed to replace the stock recovery with a Universal TWRP and now can enter in it without the reset button! Making backups is now easy!
This box (Z69 Plus) is made for that firmware!
Best wishes!
There are currently 1986 users online. 0 members and 1986 guests.
