H96 MAX - H1 TV Box RK3328 Android 7.1 4/32GB ROM Dual WiFi Gig Lan BT 4.0
    Description
    H96 MAX - H1 is a high-performance TV box, which runs on latest Android 7.1 system. Ultra-large 4GB RAM + 32GB ROM capacity ensures more smooth and flexible operation. You can enjoy high-definition image at home. And it is reliable and safe to use in your home.
    Main Features
    ● Supports 4K resolution and H.265 decoding, high-definition imaging effect
    ● 4GB RAM and 32GB ROM, ultra-large capacity allows you to enjoy more pleasure
    ● RK3328 processor ensures more smooth and flexible operation
    ● 2.4GHz and 5GHz Wi-Fi, dual-band Wi-Fi brings you high-speed wireless transfer experience
    Gearbest
    What is the difference between the H1 and H2 versions?
      Apart from some Paint been spilt on the top of this by the looks and the price nothing obvious as yet.
      Don't know exactly what's on the inside, could be different maker or same.
      Just a point of difference I guess
        I know some version of other boxes have different chips, like the 905x and 905w. I'm guessing this is a clone, but I'd like to know for sure before I spend my money. It looks like a monster for the money.
          Clone, Hmmm
          As there are many makers in China they often make the same box...
          Sometimes with same parts
          Sometimes with cheaper parts or what is available at the time.
          Trouble is who is the Clone and who in the original as they all copy each other
          Makes for fun time
            Another RK3328 to have a look at today the Colourful
            Thanks to Gearbest
            Lets Do it
            The Black Box, nothing but a sticker.
            What's in the Box, a bit of colour
            Protection removed from top
            Ports
            Removed Base and Lid.
            PCB underside
            Topside
            eMMC
            Working view
              Another one that gets a little warm but like the rest keeps on doing stuff.
              Vents around the top so has something to help the heat
              The Setup all Good of Google, Installed Apps and testing OK
              WiFi a bit slow I find tested Various channels, Ethernet OK
              Has Root with SU, also Upper and Lower Notification and Task Bar
              Simple Ui been around does the Job.
              Let's have a look see..
              UI Installed Apps
              System info etc
              DRM
              Ram and Storage Truth
              Ethernet and WiFi
              CPU-Z
              GeekBench CPU. More Info >
              http://browser.geekbench.com/v4/cpu/5747140
              Geekbench Compute
              A1 SD Bench
              AIDA64 10 Frames
                I tried to unroot so DirecTVNow would run and there are some parts of root left behind I can't seem to remove since SU is now uninstalled. Does anyone have a link to factory image or know how I can remove all the parts of root?
                  Plese i need rom h96 max h1
                    New Firmware stock:
                    As yet not tested
                    No Change log:
                    Thanks Gearbest:
                      Loaded in looking much the same:
                      Don't forget to update Google play service
                        does this software also apply to the h2 model?
                          this software also applies to the h2 model ... I have installed the software.
                          • trebor
                            trebor commented
                            Editing a comment
                            Good to know
                          Hi, i have several H96 Max H2 (colorfull edition), as reviews were good i thought let's try those.
                          They are the worst ever, crash continously, randomly shut down after minutes (yes shut down with no lights anymore, hard reset is then needed).
                          Get's really hot.
                          Now i'm trying to find a newer rom for it, perhaps the problems are related to the stock rom on it (as the problem occurs with 3 devices), i cam across the update mentioned above, will test and report back.
                          Hope someone will make a custom rom for it.
                            My H96 Max also shuts down randomly and it's annoying as hell.
