H96 MAX - H1 TV Box RK3328 Android 7.1 4/32GB ROM Dual WiFi Gig Lan BT 4.0
Thx just found the same here: https://www.youtube.com/watch?v=inN7g9YrqZ8
Only i dont have a USB-USB male cable.
Oefff,,,, it's a solution for sure, but not a pretty one.
How can they bring out such a device... amazing... China has many good Quality stuff but stuff like this brings down their name...
In the past i also had the issue with MXQ S805 with FAKE 1GB RAM (which was 512MB when inspecting) and without any form of cooling. Completely worthless crap...
Originally posted by treborH96 MAX H2 COLORFUL EDITION 4GB/64GB TV BOX FIRMWARE UPDATE 20180620
As Found
PC Flash Firmware
http://geekbuying.mediafire.com/file..._20180620/file
Flash Tool
Driver Assistant
Source: blog.geekbuying
Tried opening the update file with 7zip and with winrar both say image file is corrupt
edit 1: never mind i got it
edit 2: flashing now
edit 3: booting / "Erasing"
edit 4: Finished booting, everything seems to be working properlyLast edited by xx8todiefor6xx; 18 July 2018, 04:43.
Originally posted by trebor View PostAll Good Here
With previous firmware when I would check Kernel Auditor it would show only two cores active and two offline (would have to turn them on manually after every boot). This new Firmware shows all four cores active without me needing to do anything.
also cpu frequency is actually at max where as before it wouldnt be.
CPU running at a 44.55 C with the replacement 28mmx28mmx12mm heatsink and 120mm usb powered fan I installed
I'd thought I'd share some of the changes I've made to fix some of annoying things with this box to make it better to use.
I've changed the launcher to the atv launcher from the play store. I've also used systemui tuner and switched to immersive mode to disable the nonfiction bar completely. Another app i found is called rotation orientation manager which will force apps into landscape this is handy for apps which try and run in portrait mode.
I've also disabled the on-screen keyboard on mine since it just gets in the way.You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
There are currently 3891 users online. 1 members and 3890 guests.
