Help identify this board
The case says it a ms8+ I know it not because now brick. I believe it was a s805 chip and i couldn't upgrade past kodi 16.1. I believe what i need to unbrick is the card firmware. The usb burning tool does not detect it on my windows 10 machine. Tv doesn't detect it. it blue light and totally dead. I believe it maybe a chip short to be able to add the bootloader, What i really would like is openelec just to get it up and running is fine to. my Friend told me it use to come up MBOX. Any help appreciatedYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by nickhere View PostThe case says it a ms8+ I know it not because now brick. I believe it was a s805 chip and i couldn't upgrade past kodi 16.1. I believe what i need to unbrick is the card firmware. The usb burning tool does not detect it on my windows 10 machine. Tv doesn't detect it. it blue light and totally dead. I believe it maybe a chip short to be able to add the bootloader, What i really would like is openelec just to get it up and running is fine to. my Friend told me it use to come up MBOX. Any help appreciated
first bad Picture , i think there are serveral Elecs that can be installed , but for
flashing a box like that u can better use a Win7 Pc , if possible .
hope u can get it back to work / good luck / gefatternLast edited by gefattern; 07 December 2017, 20:13.
Hi ,
win10 usb tools does respond now to my other boxes
I did find out the flash is a 8gb
the chipset i need to remove the heat sink some howLast edited by gefattern; 07 December 2017, 20:14.
with a good Cam , near by , good light , both sides .
So it has a 8GB ROM , do you know the Wifichip ???
no Stickers to see on the PCB ???
do you have a Ethernet Port ???
please try this Rom , maybe you have a S812 :
There are currently 2285 users online. 0 members and 2285 guests.
