H96 MAX H2 4GB/32GB Android 7.1 RK3328 2.4G/5G WIFI Blutooth USB3.0
    Antonio72 i used this guys guide and was real easy to understand https://www.youtube.com/watch?v=inN7g9YrqZ8 and used Trebor's firmware image and it worked really well.Could there of been a problem when you flashed it? i dunno..
      masher17 I used this video and the update was successful. The cpu indicated 150 Fahrenheit. I may just need to buy a small fan and wait for a new update. I appreciate your input.
        Antonio72 i use a fan that works great and there is a post about the one i use..i put my TV box on top and its always cool...hope this helps you.
          masher17 thanks for the additional input. I will go shopping.
            Originally posted by Antonio72 View Post
            I ordered the H96 Max 4g/32gb and it kept crashing. I updated to the 6/20 firmware update. Now, the cpu runs hot and after watching a movie for over 90 minutes, the box crashes. Otherwise, an incredible picture. I am running 7.1. Hopefully, 8.0 and a future firmware update will remedy the crash problem. I am a novice and any advice is always appreciated.
            Maybe a fan is needed.
              There is new firmware for the 4/64 version of this box, I imagine it works on the 4/32 as well, if anyone wants to try & confirm
              H96 MAX H2 COLORFUL EDITION 4GB/64GB TV BOX FIRMWARE UPDATE 20180816
              PC Flash Firmware
              Flash Tool
              Driver Assistant
              Source: Banggood
                Thanks I might give it a try when I have some free time, just my box is 4/32 so it might mess it up.
                  H96 MAX H2 COLORFUL EDITION 4GB/32
                  4/32 GB Works :-))
                    Nemo17. Does this mean you updated the new firmware on 4g/32gb and it worked? What were some of the highlights? Thanks
                      Yes, has the firmware on. runs without faults. 4/32 GB
                        Anyone have the latest firmware for this device H96 MAX - H2 RK3328?
                        The latest firmware that I have is RK3328-BOX_7.1.2_20180620.2051_H96MAX.img. Need to update to higher android version, because cannot update latest youtube app with version 7.1.2.
                        Already tried to upgrade with firmware from RK3328 H96 MAX+ RK3328_DC_H96_Max+_HS2734C_9_20191031.2215.img, but failed, device always on boot mode and only showing H96max+ screen, so I revert back to 7.1.2
                          Latest firmware for this H2 box is the same as Mx10 pro 4k...
                          RK3328_MXQ_MX10_PRO_HS2734_8.1.0_20181013.1552.img
                          Working well on my h96 max H2 32gb box
