Pipo M7 Pro RileyROM 1.3
Did all of that work on the stock firmware?Randy
Originally posted by appledroid View PostSo far this rom is fine for me these few days, 3g , wifi are all worked.
Is there any option to move status/datetime bar into navigation bar ?? watse the FHD screen size...
According to Pipo, the screen resolution is 1920x1200 16:10
Good news M7 Pro users, I just found out today that Geekbuying.com is sending me an M7 Pro to develop with, so look for continued support for this tablet. I'm very excited!!!!!
Indications from our factory sources are that Pipo doesn't plan on introducing any new models until after the first of the year...and since this one is the newest model, I'm sure they will continue to update the firmware for it....(maybe even to Android 4.3?).
Also, our art guru, Tattman65 is working on some crazy awesome new bootanimations for Freaktab ROM's...so stay tuned!!!!!!!! There will be lots more in the future for the M7 Pro!!!!!!!!Randy
Originally posted by rrileypm View PostI don't think you can do that with 4.2.2...but there may be an app somewhere that does it.
But there are some new models will come out such as M8HD,M6P,U6,M9NOTE in September from PIPO.
Yes, I set the ROM default to US English, but you can change it in settings.
RandyRandy
Thanks a lot i have install it !
But i have edit the build.prop to add a user ( fw.max_users=2) and i can create a second user but when i log in it the system block on com.android.provision.DefaultActivity ... it's a pity to not have this feature.
have a solution ?
Or perhaps include it in the next rom update ?
I go support you with a little donationthanks !
Hopefully Pipo will release another update soon for that.
RandyRandy
Thanks, I'll be watching for it.Randy
Originally posted by rrileypm View PostThanks, I'll be watching for it.
SMS,MMS support
Thanks!!! I'll get on that today.
RandyRandy
BTW...where did you find this ROM? I couldn't find it on any of my sources.Randy
There are currently 1607 users online. 0 members and 1607 guests.
