Pipo M7 Pro RileyROM 1.3
    One more question.....
    Is this firmware wifi or 3G? It doesn't say.
    Randy
      BTW...where did you find this ROM? I couldn't find it on any of my sources.
      I get it from a Tencent QQ group about the PIPO.
        Do they have a link?...or do you just know somebody?
        BTW...I'm uploading the new ROM, now.
        Before I make the new thread, I need to know if this on is 3G or just wifi.
        Randy
          Here is the link to the new 1.4 thread:
          Randy
            We communicate with each other by a software named QQ from the Tencent,just like the MSN etc.
            They prefer to release the 3G version firmware 'cause it can use on the wifi version tablet.
              I always wondered what QQ was...it is all in Chinese...hahaha!!!!!
              I usually delete it as part of the debloat. For Chinese users, using my ROM's, is there a way to get it back easily?
              Randy
                Don't worry.QQ is the most popular app/software in China so we can get it back very very easily.
                  If you run across any updates for other Pipo tablets on QQ, can you PM me with a link?
                  It seems Pipo isn't updating their site, and my old source has stopped posting updates.
                  Randy
                    hi riley,
                    Trying to install this new rom, but i got problem when i connected usb to the tablet, the tablet only light up once it connected with usb cable, but no mass storage usb storage to be select or any action. do u have any idea on this?
                      Originally posted by pedas126 View Post
                      hi riley,
                      nothing appear in the tablet and xp pc, only the tablet will light up. pleas advise.. thanks alot
                        There is a host of causes:
                        1. bad USB cable
                        2. bad USB connection/port either on the PC or the tablet.
                        3. it won't work at all on a USB 3.0 port...only USB 2.0
                        4. USB debugging is turned on on the tablet (you must turn it off)
                        5. Rockchip drivers aren't installed properly (see First Time User's Guide)\
                        6. don't go through a hub...go directly into a USB port on the PC.
                        Included in the ROM kit is a folder with the Rockchip Batch Tool. Run it alongside the ROM flash tool and see if you get anything. You can use the switch button on that tool to boot to flash mode.
                        It takes a while to troubleshoot, but those are plenty of options to try.
                        Randy
                          1. bad USB cable
                          Hi riley,
                          thanks for the prompt reply, when i browse in Explorer apps, there are 3 location 1. SD Card, 2. Internal Memory, 3. USB , the first two got no problem to access it, and when i access the 3rd - USB, it show "The USB device has been unmounted" . is this the root cause? FYI, the tablet is running rileyrom 1.2 currently
                            USB storage is if you have a thumb drive attached. Otherwise it is un mounted.
                            Randy
                            Randy
                              Randy
                              Ic... but i have tested all points u mentioned. still not working..@@, what i can do now? frustating
                                Hi randy, finally it works, thanks, just saw ur 1.5 rom, will tested and feedback.
