T95Z Plus 2GB/16GB Bricked, No usb connection possible
Awesome!!! I've uploaded some pictures of the device.
I don't know if this is true but it seems to me that this is a clone/copy of the original T95Z Plus. The chip is a S912 as it is supposed but the Nand flash seems to be something else which I can't identify. The wifi chip is a AP6255. Do you have any thought on that?
I really appreciate your help.
Originally posted by MyVision View Post
I don't have that device anymore. But if you could disassemble it, and take a picture of the backside of the motherboard, I will draw a circle around the correct pins to short out, and send it back to you
I'll upload a picture of the back of the motherboard tomorrow as soon as I get to work.
Hello found short pin of T95Z PLUS 2G/16G AP6255 v1021
this link https://forum.freaktab.com/forum/mai...ocation/page15
Flash in maskROM mode when USB not recognized by PC or SD card not work for update
Instruction:
1) Open Android box
2) Turn upside down circuit board ( See Back board )
3) Soldering wire string on two pin for safe short circuit (to avoid damage circuit) (this step is optional)(show pin in picture attachment)
4) Connect power plug and high quality USB(male to male) to PC & Android box
5) Run "USB Burning Tool" Software load Correct image ( otherwise flashing stuck in 2 percent )
6) Set Configuration like attachment picture and click START button
7) Let's go back to circuit board and short two pin for 1 second (ongoing short pin cause flashing go to error)
8) windows recognize USB and beginning start flashing
TIP: may USB port 1 not recognize by PC, Try other USB port
Work this http://www.mediafire.com/file/f3ssbt...R3-2G.rar/file firmware on this android box version
use UART port for logging
my break android box because wrong firmware flashing( Do not match the type of RAM ) my ram is LPDDR3
Thank you to those who helped to solve this problem.
Instruction:
1) Open Android box
Thank you this firmware worked with my tv box t95z plus 2 / 16gb. I had tried 10 firm and everyone gave me 2% error in usb burning tool. This revived my Box. This one http://www.mediafire.com/file/f3ssbt...R3-2G.rar/file
Thank you emilianobilbao, i used exactly the same firmware which was the only one able to revive my T95Z Max.
It is weird since this firmware is for the T95z plus and it works perfectly on my T95Z max with 2GB DDR3 / 16GB ROM.
Actually i still searching for the real stock firmware for my T95Z Max which i am unable to find over the internet.
There are currently 2931 users online. 0 members and 2931 guests.
