Upgrade From Lollipop to Marshmallow
    I have a Minix Neo X8 Plus, I just installed the Finless ROM 2.0. Can I upgrade from Android 4.2 or 4.4 to 5.0 and higher with this ROM or there is nothing I can do? Being stuck at 4.2 has its challenges when I want to install certain software. Can anyone provide an answer I will appreciate it.
    posted in wrong section this is the amlogic s912 forum
    you have s802
    perhaps finless 1.0
    if your are just seeking the best kodi experience see libreelec forum
    cheers
      you have s802
      perhaps finless 1.0
      cheers
      Hi ,
      i moved it .
      greetings / gefattern
