I have noticed a few issues with this box I got delivered today.
1) I can't use other launchers with it as they all crash as soon as I try to open them, I have always used Nova launcher on my TV boxes. Is there any way to get 3rd party launchers working?
2) The display brightness is too dark especially in Kodi 17. I know on my s912 boxes I could change bootvideo to 1 using a buildprop editor but can't find that entry on the H96 Max, Is there anyway to brighten up the display brightness?
3) If I change the language to UK english & then go into settings - more settings - display the settings app crashes so I have to leave it set to US English, Is there any way to sort this?
4) What is the best firmware for this box, I know it used to come with android 6.0 but my box has android 7.1.2 & I feel the firmware is a bit buggy due to some of the above issues, I know there is the EntertainmentBox custom firmware for it & also SuperCeleron's firmware, which one would be the best & fix some of the above issues?
Appreciate any help given.
Cheers.
