MAGICSEE N4 TV Box Support 4K H.265 2GB + 16GB Amlogic S905X Android 7.1 2GB RAM + 16GB ROM 2.4G WiFi 100Mbps BT4.1
    Click image for larger version  Name:	20180711112648_13523.jpg Views:	1 Size:	39.2 KB ID:	741590
    Magicsee N4 TV box is a high-quality TV box. It runs on Android 6.0 system. Large capacity ensures more smooth and flexible operation. You can enjoy the high-definition images and play large games without going outside.
    Main Features:
    ● Wireless connection mode, compatible with Wi-Fi enabled devices
    ● Supports 4K resolution, enjoy high-definition imaging effect
    ● Large capacity allows you to download more applications
    ● Amlogic S905X processor ensures more smooth and flexible operation
    ● Supports HDMI 2.0 version, convenient to stream your photos, videos to TV
    Gearbest
    7.1.2 not 6.0
      Today thanks to Gearbest we can have a close look at the new improved
      Specification
      Brand: Magicsee
      Type: TV Box
      GPU: Mali-450
      System: Android 7.1
      CPU: Amlogic S905X
      Core: Cortex A53,Quad Core
      RAM Type: LPDDR3
      Max. Extended Capacity: SD card up to 64GB (not included)
      Decoder Format: H.263,H.264,H.265,HD MPEG4
      Video format: 4K,H.264,H.265
      Audio format: AAC,APE,DDP,FLAC,MP3,OGG,WAV,WMA
      Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
      Support 5.1 Surround Sound Output: Yes
      5G WiFi: No
      Bluetooth: Bluetooth 4.1
      Power Supply: Charge Adapter
      Interface: AV,DC Power Port,RJ45,SD Card Slot,SPDIF,USB2.0
      Language: Multi-language
      DVD Support: No
      HDMI Version: 2.0
      Other Functions: 3D Games,3D Video,Airplay,ISO Files,Miracast,PAL
      External Subtitle Supported: Yes
      HDMI Function: HDCP
      Power Consumption.: 2W
      RJ45 Port Speed: 100Mbps
      System Bit: 64Bit
      WiFi Chip: SSV6051P I see a RTL8723bs
      Power Type: External Power Adapter Mode
      Remote Controller Battery: 2 x AAA Battery ( not included )
      Product weight: 0.1700 kg
      Package weight: 0.4000 kg
      Product size (L x W x H): 10.00 x 9.00 x 2.00 cm / 3.94 x 3.54 x 0.79 inches
      Package size (L x W x H): 19.50 x 11.50 x 5.00 cm / 7.68 x 4.53 x 1.97 inches
      Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Power Adapter, 1 x Remote Control, 1 x English Manual
      The Box
      What's in the Box
      Ports side
      Ports read
      Remove the Base
      Out pops the PCB, heat sink and weight block, reset behind spdif port
      PCB Underside
      PCb TopSide
        An ok little unit, Rom is Dated June so needs a little work I feel.
        Usual some apps no full size, Enter Key issue.
        Do not disturb showing in Notifications, If using Keyboard need to set up Language every restart
        Just annoying niggly things that well need not be.
        We have Root with No SU, Upper and Lower Task/Notification bar
        Startup all Good Google, Wifi, update and install tester Apps etc and Don't forget play services or it will be a bit
        Let,s get looking
        UI
        Root, Upper and Lower etc
        Apps
        System Information
        DRM Information L3
        CPU-Z
        Temps Cool
        Ram and Storage Truth
        Wifi was OKish
        Geekbench CPU
        Geekbench Compute
        Ram Speed
        To summarize,
        It works, and needs a good Rom (Custom) to make it work better.
        Gearbest
          Anybody has Firmware for this TV Box, mine is working just bad.., constant Youtube stutter on 1080p, wifi or with cable speed dropping..., thanks...
            firmware m16 s905x
              Hi karpi...
              Did you try FW for this M16 TV Box and where to download..., thanks...
                Stock firmware 2/16 Blt
                MGCTV11820180627_N4_BT
                N4 S905X 20180813_N4_BT
                Very similar
                M16 ANDROID 7.1 AMLOGIC S905X TV BOX
                  b.comert - Thanks...., this Stock is pretty bad Firmware, (but thanks will be goood for backup)...even youtube on FHD (1080p) dropping frames, on 4K is horrible..., so if anybody has compatible good FW from other TV Box with S905X processor - please send informations...
                    I wrote a mail to Magicsee and they send me a link to NEW FW..., first look... much better !!!, not perfect..
                    - wifi is better,
                    - Youtube is much better even on 4K (version 2.02.14)
                    -OS somehow snappyer,
                    -faster apk installation through Appinstaller...,
                    -Set Orientation.apk still needed to set to landscape...,
                    -wireless update still not working...
                    Here is a link:
                    https://mega.nz/#!dfwyXSqD!Dlwsi4Er2...MuOFW9ErmB0V0A
                    1. Open Amlogic USB burning tool
                    2. Load image
                    3. press Start
                    4. stick toothpick to SPDIF whole and keep pressing - Connect TV box with usb cable (next to power)...
                    5. When computer recognize TV Box remove toothpick and flashing will start
                    6. Green 100% - succesfull.. - disconect TV box and voila...
                      Originally posted by b.comert View Post
                      M16 FW is working good and everything is working just fine and really fast (much faster than Stock ROM).., wifi OK, remote OK..., BT OK..., working temperature is much lower (4K Youtube is working better and about 60C)...
                      Sistem UI is only 720p...shame..., despite settings which shows 1080p resolutions..
                      But if you update su binary - BOOTLOOP..., - so DO NOT UPDATE SU BINARY..., or if you do not need root - just disable SuperSu aplication....
                        And this is a working TWRP for N4!
                        https://mega.nz/#!6U0klSKL!j9FTWS7fg..._8QB9_mGiXzjrI
                          - wifi is better,
                          Here is a link:
                          2. Load image
                          3. press Start
                          Updated to this firmware and remote stopped working.Anyone got remote.conf for the magicsee N4?
                            It is Original - Stock FW - it is impossible that remote stop working..., I flashed this and everything is working....
                            Here is original Remote.conf for Magisee N4 - https://drive.google.com/file/d/1Uhz...ew?usp=sharing
                              Thank you. Going to try it now I got different remote then the one in the review?
