MAGICSEE N4 TV Box Support 4K H.265 2GB + 16GB Amlogic S905X Android 7.1 2GB RAM + 16GB ROM 2.4G WiFi 100Mbps BT4.1
Read the post 10, before that first install Amlogic USB burning tool with Tv Box connected ...
For this you will need usb cable male to male...
https://images.app.goo.gl/T63H4xKo9RS9bgyT9
I have found recently an M16 2/16 firmware but since i don't have this tv box anymore i can't test it!
But i've already checked it with Md5 Checker and shows that it is not the same firmware with the ''M16_S905X_20171030.img'' !
So if anyone still have this tv box and wants to test it and share the results here it is :
http://firmware.duckdns.org/firmware...ble_online.img
Originally posted by gatos814 View PostI have found recently an M16 2/16 firmware but since i don't have this tv box anymore i can't test it!
Hola amigo lleno de savia tengo problema quiero reiniciar mi magicsee n4 he visto todo pop O ppooppoooopplos archivos para descargar que has dado, ya los he descargar ipero no se como intalarlo en tvbox no hay algun tutorial o una mejor explicacion para instalarlo, mi tvbox magicsee n4 se queda pegado en el segundo logo el de magicsee se queda parpadeando como si fuera q va iniciar pero no inicia ya entre al modo recovery y sale no comand el robot de android, lo he reseteado de fabrica pero igual no inicia se queda en el segundo logo otra vez no cpmienza no habr? por favor quisiera ayuda como hacer para intalar el harware o para que enpiese de nuevo algun tutorial como instalar espero me puedas ayudar lleno de savia
Originally posted by Ptamiguel View Posthi apology can you help me how to update the firmware of the tv box magicsee N4 I already have the file but I do not know how to install
Originally posted by pdjm View PostatvXperience rom for magicsee n5, version G
Works on magicsee n4, did not had the time to fully test it but seems to work welllink is dead
Merry Christmas!
If anyone want to update the Magicsee N4 I'v made a fully working (youtube, wifi works) rom based on the original N5 firmware (which I couldn't boot on my N4), the software is dated 10.V.2019
SHA256:751B54B18CBA83BBADDEB2580803B4D0E0611D362DD C9DB2C7DA755CE249F511
https://mega.nz/file/dZJFiIZI#oHsSp_...qBaOcjcyoV5lMI
I flashed it using USB Burning tool 2.2.0.
Update:
Hi, I've also made and successfully flashed a newer firmware to the Magicsee N4 it is dated 28.VI.2019
SHA256: 2DB05EA12B2AC35723E5FA25A40520BE346A100CE7E1A7F051 BE03C10EF4C864
https://mega.nz/file/pARHVYKb#p0Gevh...1jZa-8UeyTSgEU
There are currently 2945 users online. 1 members and 2944 guests.
