Modify on MK809III ( IR control,cooling fan ,box .......)
Originally posted by Howard View Post[ATTACH=CONFIG]3023[/ATTACH]
[ATTACH=CONFIG]3024[/ATTACH]
[ATTACH=CONFIG]3025[/ATTACH]
[ATTACH=CONFIG]3026[/ATTACH]
[ATTACH=CONFIG]3027[/ATTACH]
i made mine, i cut 2 usb cable and get from my old computers two amd cooler fan, i have inserted the red and the green cable (of one cutted usb cable) and inserted inside red and black cables of cooler amd fan
after i cut my original case sides and used glue to insert the coolers at each side. i use tv usb connectors to fan and i connect my mk809iii at normal mode and i liked very much the results!
i dont have a beautiful case like yours but mine "case" (lol that is two fans at each side!) is working fine, it is not getting warm
now i just need a software for it
In my modifications ,I am satisfied with my IR remote controller controlling the power to the stick by one button on my SONy TV IR controller.So I can power off the TV and the stick in the bed.
I think in the next time modification the fan power should be controlled by the TV remote controller.Then it is perfect.
HowardLast edited by Howard; 25 August 2013, 01:10.
Originally posted by Howard View PostI don't think it need cooling down by fan every time.Mine is overclocked (1.8G cpu,1500Mhz RAM),it works fine if switch off the fan.I only switch on the fan when playing big game.
Howard
What games you play
Originally posted by Adainair View PostHi Howard
Intersting mod can you share with us more information about IR receiver how is connected to mini PC or maybe link.
I am seen in dmesg to mini PC have support for many IR brands but did not have time to test it yet.
I got the receiver from china market .It is a DIY product.The controller chip is polished ,so I don't know the SPEC.I think you can got the IR receiver from TV inside
Any way I attached a PIC
There are currently 2117 users online. 0 members and 2117 guests.
