MXQ PRO+ ANDROID 7.1.2 AMLOGIC S905X 2GB/16GB TV BOX FIRMWARE UPDATE 20171220
    Hey guys,
    Glad to share the firmware for MXQ PRO+ TV Box
    PC Flash Firmware
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Have fun !
    Hi , I have install this firmware , but wireless have problem conect , Please any solution ?
      I have bought two of them , and have the same problem and after update to this firmware
        maybe yes... disassembly your box(es) and tell me what type/model of WiFi chip have you inside.
        Also previous version build name (if you remember it).
          Hello,mxq pro RK3229 的 wifi chip - SSV6051
            They're asking for MXQ PRO+ amlogic platform, not rockchip :]
              sorry for that,MXQ PRO+ S905x wifi chip : HS2734
                Hello,
                could you please tell us your order number?
                we will help you process the problem.
                  Hello,
                  until he answer, provide us link to download latest firmware build with HS2734 support
                    Hello,
                    it is the new firmware http://blog.geekbuying.com/2018/01/m...date-20180126/
                      you can check http://blog.geekbuying.com/2018/01/m...date-20180126/
                        If i write here , I have bought on Geekbuying and that why I ask you , MXQPRO + S905X if you want my order number to now exactly the product
                          hope this new firmware work , the last one has not fix
                            4359759 Order number
                              any note what s is fixt ?
