MXQ PRO+ ANDROID 7.1.2 AMLOGIC S905X 2GB/16GB TV BOX FIRMWARE UPDATE 20171220
Originally posted by wolfheart79 View PostIf i write here , I have bought on Geekbuying and that why I ask you , MXQPRO + S905X if you want my order number to now exactly the product
as we need to know the order number, our customer service [email protected] can check it and help you process the problem.
and thanks for your feedback.
glad to hear that your problem is solved.Coupons Updated Every Day: https://bit.ly/2RnbHUi
Originally posted by mXHX View PostGeekBuying_Rep and anyone other. How to unroot this device or replace stock root to SuperSU ?Coupons Updated Every Day: https://bit.ly/2RnbHUi
Originally posted by GeekBuying_Rep View Post
you can unroot it by https://tusanhuan2-my.sharepoint.com...0-84456cf04915
We're sorry, but ....@.... can't be found in the tusanhuan2-my.sharepoint.com directory. Please try again later, while we try to automatically fix this for you.
If that doesn't help, contact your support team and include these technical details:
Correlation ID: 3d50469e-70a5-5000-f006-70bec723eb37
Date and Time: 2018/2/1 11:28:01
URL: https://tusanhuan2-my.sharepoint.com...0-84456cf04915
User: [email protected]
Issue Type: User not in directory.
Sorry but the link not works.... :/ That didn't work
you can pay attention to it.
I got the box on Friday - purchased it from your e-shop.
The box is running "s905x013-userdebug 7.1.2 NHG47L 20171122 test-keys" firmware. It's painfully slow, particularly its launcher, which I don't mind, but the main problem I certainly don't like is the video playback. Most of the 1080p x265/HEVC 10bit movies I've tested exhibit marked stuttering (jumpy, choppy, laggy, especially when the camera is moving as opposed to its static position) in all the tested apps (MX Player, VLC Player, KODI). Ironically enough, the 4K x265/HEVC 10bit video I tested plays somewhat fine. Youtube streaming works fine as well, albeit the wi-fi reception is very poor.
Can you tell me whether the "s905x MXQ PRO+ 2018.01.26" firmware update eliminates these issues or not? The video playback of the HEVC/10bit files - the main reason I bought the box for - is currently unusuable. I want you to help me solve the issue, please.
Thanks in advance.
Regards
EDIT: My 9 year old PC plays the 1080p x265/HEVC 10bit files more smoothly using SW acceleration than the MXQ PRO+ using hardware acceleration!
EDIT 2: Successfuly flashed the "s905x MXQ PRO+ 2018.01.26" firmware, but the situation is still the same, nothing has changed. Moreover, the new Youtube app makes the video quality even worse! Please, help. Do you have any recommendation for a reliable custom firmware, please?
EDIT 3: Solved the issue running LibreELEC + KODI (8.2.3.1) - the playback is extremely smooth, just perfect. Different refresh rates of the videos seem to be the culprit and Android can't handle it properly. (it's mostly 1920x1080 at 60Hz vs. 1920x1080 at 24Hz)Last edited by MiDe3; 02-22-2018, 05:09.
Originally posted by MiDe3 View Post
Thanks in advance.
Regards
really thanks for your feedback.
glad to hear that your problems are solved.
we will update the firmware soon if any news from supplier.
and if you have any other questions,just tell us.
we will help you process it.
Regards,
There are currently 1690 users online. 6 members and 1684 guests.
