Lenovo G66 TV Box - RK3288 / Android 5.1.1 / 2/16GB ROM / 2.4G + 5.8G Wi-Fi / 100Mbps / BT4.1
    Descriptions
    Lenovo G66 is a high-performance TV box, which runs on steady Android 5.1.1 system. Large 2GB RAM + 16GB ROM capacity ensures more smooth and flexible operation. You can enjoy high-definition image at home. And it is reliable and safe to use in your home.
    Main Features
    ● 2GB RAM and 16GB ROM, large capacity allows you to enjoy more pleasure
    ● RK3288 processor ensures more smooth and flexible operation
    ● 2.4GHz and 5.8GHz Wi-Fi, dual-band Wi-Fi brings you high-speed wireless transfer experience
    ● Supports many different video, audio, and photo formats
    Gearbest
    Today we can have look see at the
    We can step back in time to when the 3288 was King (maybe)
    This Unit does have a History
    It going to be a Games only type of unit google is you friend on this
    Guess it did not make it
    Now here it is Android 5.1, a good speck extremely well built groovy look and hardly any ports sad really.
    So lets have a look.
    The Box, Huge and well packed
    What's in the box
    Ports and that's it
    Lets Pull it to Bits
    Done
    Seriously now, Pop the Cover, Power Touch Off/On switch, top PCB part of Blue LED show and Only Blue so far
    Look around: Side, excellent thermal design
    Other Side, all that alloy
    Top Side Led stuff and some Venting or a Fan evan
    Bottom Side, and Heat sink 1
    Removed and not much to see Underside
    Topside even less to show all covers soldered on
    More destruction, WiFi Antenna and one on the other side
    Heat Sink 2 the wrap around
    All back together and working
    Here you can see the Base plate with Vents, the top has a grill I gather its for venting and all that Alloy Excellent Thermal design.
    As seen well Built, not just a PCB slapped into a Clam shell
    As mentioned great Build pity it did not make it...
    Tests Later
    Gearbest
      Continuing on with a look at UI system etc
      Running Android 5.1 and being a RK3288 it does ok I am finding
      Google and startup/setup and installing apps all Good
      One USB port well out with a Mini USB hub for keyboard and Included Remote with Dongle
      Remotes works excellent, No 100% Keyboard friendly easy fit later
      No SD card slot
      One USB Port
      No Root access or Task Bars
      WiFi Excellent, Ethernet as expected I found.
      BT Deaf as a post at present not sure why,
      Onto the the Look around.
      UI Installed Apps
      Settings
      System information
      Ram and Storage Truth
      CPU-Z
      Geekbench CPU.
      More Info >
      http://browser.geekbench.com/v4/cpu/6371892
      Geekbench Computer
      Kodi 17.6 Installed, no app would read temps.
      Plus you can see in Apps all the others installed
      A1 SD Bench
      Found a QR code on the Box, thought it might to lead to something interesting.
      Called Mini Station APK, maybe full of games and stuff there own little Spot..
      Nope an APP in Chinese, I believe for paring phone and sharing from what I could gather
      A quick look may have a use.
      A Well made good looking Unit for sure, may get lucky with a custom Rom or some other joy, ok as it is Social games, Web interactions etc.
      Netflix had a Sync problem drop to 24hz fixed that one and Just BT at present may Antenna to plugged on 100% after the show and tell.
      You could leave on the Mantelpiece or coffee table plugged in when guest arrive..has a interesting look.
      Did discover when there is no Network Connection/Internet the Led displays On bar flashed RED
      Gearbest
        Wow, $70 USD, Thanks, but no thanks.
          A nice bit of coffee table furniture.....I know has no clock....
          I did get BT to connect to the Phone but no other device seen..Must be some special BT..
            Yes the price looks a little bit high, but the hardware is very well selected. This RK3288 will never run hot, because they have built a remarkable cooler pipe system.
            I see just two weak points, only one usb port and the standard 5.11 ROM, nothing special inside and some useless apps.
            The gaming system part is only in the Chinese Version, but of course in Chinese language.
            JD
              When we received this we hunted down the original Tencent OS, although in korean, a big step up from the android system that now comes nstalled.
                Where can I find rom stock and rom cook?
                Thank you.
                  Official ROM is Tencent OS based on Android 4.4,so this 5.1.1 was built by someone else?Thus BT not working so well as the stock ROM,and the UI need to be beautified SERIOUSLY!
                  Where is this 5.1.1 ROM? I believe this forum has several gurus who can improve much better.Pls share the forum with this ROM,thanks.
                    Hello,
                    I already try to make ROM.
                    But that Device is special.
                    Needs special Bootloader and It has an property Wifi Chip inside where no drivers exist.
                    Neomode
                      Hi,neomode,
                      So glad you surfaced.
                      The wifi chip is AP6356s,should be broadcom's wifi&bluetooth chip,brcm shall work but needs more refinement for bluetooth.I guess the OP's ROM use generic that's why bluetooth doesn't work.Also it's due to the special chip that the stock ROM always enables wifi for mobile to mirror & control.
                      Maybe you can extract from the stock rom the kernel for some analysis and use?
                        There is a link to original tencent recovery rom http://ms.myapp.com/myapp/ministatio...ion_update.zip
                        but i don“t know to install
                          Hi ,
                          use Androidtool 2.35 or higher and u need RKDrivers 4.4/4.5 ,
                          http://ugoos.net/blog/rockchip-firmw...flashing-guide
                          http://ugoos.net/blog/reflashing-in-maskrom-mode-if-device-bricked
                          follow Instructions for restore . If something unclear ask ,
                          greetings / gefattern
                            Hello! ordered a G66 console! and where to get the firmware 5.1.1?
                            • trebor
                              trebor commented
                              Editing a comment
                              Have tried but no luck so far
                            Hi ,
                            that was no good idea , this Box is not well supported and with A5.1 it has a to old
                            Firmware , the Wifichip is a different one to all other Boxes with that Chip , most used
                            AP6335 , so you will not be able to use other Roms , hope you can be happy with the
                            stock A4.4 Rom from Years ago , even many Apps shall maybe not work with this Box ,
                            good luck / gefattern
