but get the root?
Lenovo G66 TV Box - RK3288 / Android 5.1.1 / 2/16GB ROM / 2.4G + 5.8G Wi-Fi / 100Mbps / BT4.1
Good evening! Dumped the firmware dump of this device. And checked by pouring it into the device. Everything went fine. And I found the contacts of the test point. I installed firmware from UGOOS UT3 / UT3S. They are set normally, but WI-Fi does not work. In the themes RK3288 found custom recovery, TWRP and CWM. But neither the remote control nor the mouse worked in it. The translator wrote through Google, do not judge strictly.
Firmware
Originally posted by Pavluha View PostGood evening! Dumped the firmware dump of this device. And checked by pouring it into the device. Everything went fine. And I found the contacts of the test point. I installed firmware from UGOOS UT3 / UT3S. They are set normally, but WI-Fi does not work. In the themes RK3288 found custom recovery, TWRP and CWM. But neither the remote control nor the mouse worked in it. The translator wrote through Google, do not judge strictly.
Firmware
Different wifi chip and different remote code in the dts file in the kernel.
Originally posted by Pavluha View PostI know that there is another chip. I meant that she gets up, and she is with the root. You can at least start experimenting with something.
IR not work in TWRPor CWM.
I just forgot,this box doesn't have a IR component.
The remote works with a 2.4g dongle receiver actually,certainly not working in TWRP or CWM.
I guess Lenovo & Tencent used to have an ambitious plan for online gaming business on this model,but they gave up.
I wonder where to get this android 5.1.1 firmware to upgrade?I got mine stuck in 4.4.1.The dump can only be written through an expensive EMMC programmer.
And Rockchip has rolled out andorid 7.0 for RK3288,but no customized firmware for this machine just because of the proprietary chip?
Originally posted by Pavluha View PostI was able to add our drivers from Lan to the Ugoos firmware. Lan network works fine. But I can not find the driver from WIFI. Where can they be located? In which folder?
The wifi & blue chip is AP6536S.
Some dev guy in China has already had solution for this chip with RK3288 on android 6.
Update the driver & nvram for wifi &BT.May need to compile the kernel I guess,I am not ROM developer.
This machine has good heat sink design and no lagging of online video,good EMMC.
Using google translation https://blog.csdn.net/kris_fei/article/details/87630882
文章浏览阅读3.3k次,点赞3次,收藏9次。在RK3288平台上,运行Android 6.0系统,使用AP6356S Wi-Fi芯片进行2.4G/5G传输速率测试时,发现其速度仅为RK3399平台的一半。问题源于RK3288默认采用SDIO 2.0,最大时钟频率为50MHz,而RK3399支持SDIO 3.0,最大时钟可达150MHz。为提升速率,需要将RK3288的SDIO电源电压从3.3V调整到1.8V,以支持SDIO 3.0标准。解决方案涉及电压和时钟频率的调整。
And RK3288 can be built on Android 7 now with the latest SDK,it should be not difficult for ROM developers,but no one care to customize one now.
The official 4.4.1 firmware is here: http://ms.myapp.com/myapp/ministation/app_rom/lx/miniStation_update.zip
After install,get an OTA update,but still 4.4.1.
You may extract some useful files if needed.
And one question is that how did you dump the whole firmware?Just how?
How to pour into the device again? Pls provide more details or steps.
Stuck with 4.4.2 and no ROM developer cares to customize a 5.1.1 or 7.1 firmware for this device.
thanks.
There are currently 2277 users online. 1 members and 2276 guests.
