i cant find this :S
CWM recovery ask
Re: CWM recovery ask
Originally posted by MARIANOTE View Postplease someone can post a link to CWM recovery for cx919? thanks...
i cant find this :S
Originally posted by leolas View PostCx919 is a rk3188 device? If it is then there is not any specific image for cwm for cx919, if you upload your stock recovery.img I can do it for you, or you can use the gereric rk3188 from androtab web.
leolas
Originally posted by MARIANOTE View Postthanks i will looking for that, searching androtab now
gracias leolas, he leido por ahi que hay que flashear la rom con un recovery normal y luego el cwm en otro flasheo solo para no perder la SD interna
si ya tengo funcionando Finless 1.4 bien y quiero poner el CWm solo sera flashear el CWM no? con la herramienta de finless y el loader ese de rk3188
otra duda que me surge es qye tengo solo raton, no teclado, se puede usar con raton?
saludos
PS: sorry i see the guy is from spain!!!
Hi
i was trying to flash the RK30GENERIC_CWM, renaming to update.zip to my CX919 and the result is blank screen after rebooting. Dont know if we need an specific version.
I was doing two tries...first with neomode rom 1.3 then with finless rom 1.5 but after i update with the supposed CWM for Rk3188 devices the stick is not booting anymore.
Please can you help me?
Thx in advance.
Thx in advance.
reboot cx919 complete
shutdown cx919
flash cwm via bobs tool for 1.4 o 1.5 finless and only flash recovery.img from cwm and loaderRK3188
that must work
remember rk3188 has no cwm, is a port from 3066 i think and need usb keyboard to work in it
Originally posted by MARIANOTE View Postgracias leolas, he leido por ahi que hay que flashear la rom con un recovery normal y luego el cwm en otro flasheo solo para no perder la SD interna
saludos
Si con el raton tb se puede user, si mueves desde abajo a arriba equivale a flecha arriba en el teclado, de arriba para abajo flecha abajo, etc...
Thx in advance.
Enviado desde mi folio100 usando Tapatalk 2REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostLo siento no vi este post, correcto solo flashear el cwmrecovery.img con el flash tool de Finless o neomode.
Renaming to update.zip don't work in rk3188 devices, you need to install it using a flash tool or adb following the fun instructions in androtab
nandroid backup work ok? can restore rom from cwm in 3188 devices?
La única pega es no tener el kernel dentro del recovery, si hay algún problema con el único kernel q está en la partición de kernel, hay q usar el pc.
Voy a hacer cwm recoverys para varios dispositivos basados en el recovery de fun.
Originally posted by leolas View PostFunciona estupendamente para mi en mi modded cwm recovery in qx1, todas las opciones, backup, restore, install zips, adb en recovery, format, wipes, etc...
leolas
es que la gente decia que no se podian instalar rom desde zip, supongo que es por lo del kernel, digo en cx919
Li de instalar roms desde el zip, lo siento pero solo yo hago roms para el qx1(único rk3188 q tengo) los demás prefieren instalarlas usando pc, pero igual q hice en los rk3066, tengo pensado hacer zips modelos, para q podáis usar esos zips siguiendo unas sencillas instrucciones para instalar cualquier rom. Este finde que vuelvo de las vacaciones empezaré a hacer los recoverys y los zips.
Muchas gracias por vuestra ayuda. Yo tengo instalada la neomode rom 1.3 que bajo mi punto de vista va mejor que la finless rom 1.5 (al menos a nivel de velocidad despues de pasar los test con antutu). Como no tengo claro lo que me dices te lo repito y me das tu ok vale?
Tengo que flashear con ROM_Flash_Tool_137.exe el fichero recovery.img que hay dentro del fichero RK30GENERIC_CWM.ZIP (el generico del RK3188 que es solo ramdisk) y poner de loader el fichero RK3188Loader(L)_V1.20.bin, desmarco todas las opciones y solo dejo estas dos pestañas desde el Finless Rom Flash Tool v1.37
Es correcto?
Originally posted by supertilico2001 View PostMuchas gracias por vuestra ayuda. Yo tengo instalada la neomode rom 1.3 que bajo mi punto de vista va mejor que la finless rom 1.5 (al menos a nivel de velocidad despues de pasar los test con antutu). Como no tengo claro lo que me dices te lo repito y me das tu ok vale?
Es correcto?
Originally posted by leolas View PostNo, sólo marcar el recovery y poner el q hay dentro del zip. Esta tarde llego a casa, y trad desacer el equipaje me pondré manos a la obra con hacer cwm recoverys con kernel, así q si me decís los sticks q tenéis, os voy haciendo los cwm recoverys y os doy un link para poder instalarlos desde terminal emulator, de manera fácil y sencilla.
leolas
si pones un how to con eso del terminal emulator... o si es mas facil con RKflashtool no se a mi me jodio el mk802 una cosa que hice con terminal emulator ;S
gracias por la onda!
There are currently 2202 users online. 2 members and 2200 guests.
